Author Topic: How to tell piston sizes  (Read 2700 times)
Offline CraigBa
« on: November 16, 2014, 05:56:40 pm »
A couple of questions for you knowledgeable people
1. Changing the rings and piston on my 89 CR125 and need to find out the piston sizes. How do I find this out?
2. The current piston has one ring but it seems they also some with two rings. Is there a reason?
3. There is a tiny bit of cross movement on the connecting rod. Is this normal?
Craig
"It is a thousand times better to have common sense without education than to have education without common sense".
MV Agusta Brutale
89 Honda CR125
89 Honda CR500
Offline CRTAD313
Re: How to tell piston sizes
« Reply #1 on: November 16, 2014, 06:21:42 pm »
 The standard bore should be 54mm and will be nicasil so it can't be bored out unless it's been re sleeved. The standard piston was one ring. From my limited understanding there are pros and cons of single vs double rings, but I'll let someone with a better understanding go into that. It is normal to have some cross movement, if unsure get someone in the know to have a look.
« Reply #2 on: November 16, 2014, 06:42:20 pm »
Yes cross movement is normal in the B/End sideways  @16 thou total.
