Author Topic: rm 400 t seat base  (Read 2536 times)
Offline LeighW
rm 400 t seat base
« on: October 27, 2014, 01:31:32 pm »
hi all looking for a good seat base to suit rm 400 t  cheers leigh
Re: rm 400 t seat base
« Reply #1 on: October 27, 2014, 04:30:20 pm »
Pe 250-400 T/X  share the same base.  The front rail bracket is a universal fit .... drill out rivets and refit  ;)
Offline rocketfrog
« Reply #2 on: October 29, 2014, 09:38:39 am »
Are you sure that the PE seat base is the same as RM400T? I thought the PE has a longer tank and shorter seat. (maybe an optical illusion)
I would like to be wrong on this as that would suggest that the RM seat foam would be the same as the PE.  RM250/400T seat foam is available but I cannot find a seat foam listing for PE250T anywhere.
If this is a fact that the RM and PE seat bases are the same please let me know!
Cheers Jason
« Reply #3 on: October 29, 2014, 12:01:09 pm »
Read the second sentence ..... if it's a Pe seat base you will see  a hole each side in the front of bracket . Rm are brought forward and a hole will be at the back.
Seat foam and covers are different in shape
Offline Yamahaha
  • Melbourne Vic
« Reply #4 on: October 29, 2014, 12:57:42 pm »
Geez Leigh why do you need the seat base haha ???? how's the ass??
YZ 250 modern, YZ 125G, YZ 125E, IT 400D, IT 175G x 2, YZ 400F CR250re,  2012 yz450fse Service Honda CR500AF.   Viper #73
Offline rocketfrog
« Reply #5 on: October 29, 2014, 01:46:58 pm »
OK, so apart from the position of the forward bracket the base is the same part, yes?
So has anyone tried to fit a RM seat foam to PE? Does the foam have the same "Footprint" on the base, anyone know?
Is it a matter of reshaping the top sides front and back slightly to achieve the same contour as the genuine PE foam.
« Reply #6 on: October 29, 2014, 05:55:49 pm »
yes
« Last Edit: October 29, 2014, 06:25:56 pm by oldfart »
Offline rocketfrog
« Reply #7 on: October 29, 2014, 09:35:56 pm »
Great news, can you also tell me if the rear seat bracket is the same for RM and PE?
Does the RM have the hook on the left and a full bolt circle on the right like the PE? The frame looks very similar except for the rear loop area on the face of things.
