Author Topic: Pointless ign conversion for an old ct125  (Read 4155 times)
« on: October 23, 2014, 10:40:27 am »
whats the go here? can it be done ???
Offline Mike52
  • 81 KTM 125 LC
Re: Pointless ign conversion for an old ct125
« Reply #1 on: October 23, 2014, 12:10:11 pm »
Yer the postie bike change over from points to cdi in about 1981 used a setup that should fit.
The pickup was up in the points cover and used the points advance setup.
« Reply #2 on: October 27, 2014, 03:21:24 pm »
 This being the non step-thru type agi/postie Honda you are inquiring about I believe?
CT125 points to CDI. A lot of work... Like one engine design has the charge circuit hardware in the sump oil like the older SL125 and the other (CDI) not..... Easiest way/fix is to find a  complete post 1979 CT125 engine and just bolt it in. Been there and done both. Tim754
« Last Edit: October 27, 2014, 03:25:44 pm by Tim754 »
« Reply #3 on: October 27, 2014, 04:35:54 pm »
so true, unless ya want SL gearing, then its all engines down and swap,so its like Tim said, or getter later XL125 donk if ya not classist or is that a flow on case Tim?
« Reply #4 on: October 28, 2014, 07:16:17 pm »
 XL125  Pre78 onwards. Two piece heads.   8)
and that shelf did collapse when tossed another five or ten engines on it.................... >:(
« Last Edit: October 28, 2014, 07:18:39 pm by Tim754 »
« Reply #5 on: October 29, 2014, 10:50:01 am »
 :) :D ;D :o
