Author Topic: Footpegs advice YZ and RM  (Read 7811 times)
Offline YZAT252
« on: September 12, 2014, 04:21:54 pm »
Hi, trying to source some decent pegs for YZ250G and RM125B. I spoke to Les at VMX unlimited, he can't help me as Proform don't do them for that model RM, and they make them for the YZ but he can't get stock at the moment. Anybody know what will fit these bikes off another model without too much modifications needed?
Re: Footpegs advice YZ and RM
« Reply #1 on: September 12, 2014, 05:23:01 pm »
Current RM85 footpegs fit the B.....fit 10mm pins as well to get rid of the flogged out holes.
Offline Ted
« Reply #2 on: September 12, 2014, 06:16:08 pm »
Buy the YZ proform pegs from dcvmx.com
You can also use footpegs wideners from GMC or Ballards for the B.
With the B just check the welds around the footpegs. We had a peg just shear the welded bracket straight off the frame the other week on this model. Wider , longer pegs will place more stress on these welds. I will be welding a strap right around the bottom frame rail to strengthen the area. We nearly DNS for the meeting just one lap into practice.
81 YZ 465 H   77 RM 125 B
Offline Ken 737
« Reply #3 on: September 12, 2014, 07:26:42 pm »
Craig, to reduce the chance of the problem Ted refers to, perhaps the easiest solution is to weld a set of wideners from Ballards, etc.
Ken
See you at Harrisville next weekend!
Suzuki fan - TM and RM
Love my IT too ????
Offline Jumbo J
« Reply #4 on: September 12, 2014, 07:35:10 pm »
will RM B pegs fit a TM. they are wider right?
« Reply #5 on: September 12, 2014, 08:04:43 pm »
Late model YZ pegs fit old model YZs with a little bit of grinding. Gotta use the late model return springs too.
« Reply #6 on: September 13, 2014, 08:19:42 am »
Jumbo ...  Rm   1993  are the ticket on Tm
Offline Jumbo J
« Reply #7 on: September 13, 2014, 09:22:56 am »
helpful and constructive as usual Stew. thx will keep an eye out for some 93's
« Reply #8 on: September 13, 2014, 10:53:24 am »
How the springs attach to base of frame mount is a pain ..... ended up welding a little tag in place.
Offline Jumbo J
« Reply #9 on: September 13, 2014, 11:14:42 am »
no springs on the orig ones so will probably leave as is on RM's. already got a set lined up with a guy
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=151285632117
any good?
Offline crossedup2
  • Never enough shed time.....
« Reply #10 on: September 13, 2014, 11:36:10 am »
I have several of my yamaha YZ and IT fitted with these.
Little bit of fiddling to get them to fit, like drilling out the pin hole for bigger pins.
http://www.ebay.com.au/itm/290779951202?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I've used the original spring in most cases.
Peter B
« Reply #11 on: September 13, 2014, 12:47:40 pm »
Jumbo ... if postage is not over the top ,  go for it.
« Reply #12 on: September 13, 2014, 12:55:18 pm »
any good?
Those pegs have wideners welded to the outside of the original pegs.
Personaly I believe the gap inbetween the 2 serated parts end up mud catchers
I don't beleive they are worth bringing in from the states, surely there must be a better set out there somewhere?
