Author Topic: Wheel bearing removal - TM250.  (Read 2398 times)
« on: July 04, 2008, 11:39:04 am »
Whats the trick? I have removed plenty of wheel bearings in the past by reaching through with a long drift, picking up the edge of the bearings and tapping it out working around the edge of the bearing. With the TM I can't tilt the centre spacer enough to pick up the edge of the bearing, neither side. Whats the trick?
Offline crs-and-rms
  • heaven 23
Re: Wheel bearing removal - TM250.
« Reply #1 on: July 04, 2008, 01:54:35 pm »
thats the way ive allways done it to
« Reply #2 on: July 04, 2008, 03:16:07 pm »
Buy a split collet remover and you will never look back . Or remove bearing cage and make up a bearing puller that fits into the race ( shaped like a " T " ) easy to make out of an old bolt and 5 minute's on the grinder .
« Reply #3 on: July 05, 2008, 04:43:01 pm »
I'm lacking in imagination ::) - can you post a pixie ???
« Reply #4 on: July 06, 2008, 06:10:54 pm »
Get an m6 dyna bolt flatten the expanded end so it is same thickness as race , then file away as in pic making sure you round the ends so as to be a snug fit - make your self up some sort of slide hammer . The collet puller .... fits inside the bearing catching on the bevel - 2 hits with the slide hammer and out they come
« Last Edit: July 06, 2008, 06:12:26 pm by oldfart »
