Author Topic: Kramit RV3 Rebuild  (Read 112528 times)
Offline Moto
Re: Kramit RV3 Rebuild
« Reply #15 on: July 24, 2014, 08:45:56 pm »
Degrease them thoroughly and put them in a bucket of Molases mixed with water at 4:1(ie 4 water -1 molases) leave the bucket outside(it smells) for a week or more.The mixture only eats rust.
Molases can be bought cheaply at your local farm produce store.
I  use it to clean up all my rusty parts,works a treat.
WARNING Do not use on alloys or magnesium,it will dissolve them too.
« Last Edit: July 24, 2014, 09:10:35 pm by Moto »
« Reply #16 on: July 24, 2014, 09:22:11 pm »
the platers give a supersonic clean don't they?. I would go and buy a box of 6, 8 and 10mm nylocks and just do the bolts.
Offline NSR
  • Sunshine Coast
« Reply #17 on: July 24, 2014, 09:29:15 pm »
Yeah I will be doing that.  Its the bolts, clips and small parts I need the rust off.
Offline Tomas
« Reply #18 on: July 24, 2014, 10:48:37 pm »
Offline sa63
« Reply #19 on: July 25, 2014, 07:43:51 am »
any acid will work to remove rust, just the strength is the issue. I use diluted hydrochloric acid. works really fast- be warned  if you forget the part in the acid it may be destroyed or gone!
I give a Quick wire brush and  just dip and brush until clean(couple of minutes), but the plater will also acid strip everything.
I like to acid clean before welding any old parts, getting rid of the plating stops the eye blinding flashes if tigging
« Last Edit: July 25, 2014, 09:21:14 am by sa63 »
Offline euro bikes
« Reply #20 on: July 26, 2014, 09:03:53 pm »
 A wire wheel on your bench grinder.
Offline KTM47
« Reply #21 on: July 26, 2014, 10:24:31 pm »
There is a product called Rost Off and Rost Off ice Wurth sell it.
Rosco Holden used a product called Protec Metal Conditioner Degreaser to clean the pipes he got from the Flood collection.
Or aluminium cleaner will also do something similar
Kevin
MAICOS RULE DESPITE THE FOOLS
Offline NSR
  • Sunshine Coast
« Reply #22 on: August 03, 2014, 07:15:06 pm »
Are these forks WP or Marzocchi Forks?  Whatever they are has anyone got any settings (Oil weight spring Pre load etc.) for them?
Offline gra1961
« Reply #23 on: August 06, 2014, 07:23:00 am »
they look different to the wp on my 86 ktms,different looking caps and whatever that is over the dampening rods is not on the wp's
Offline NSR
  • Sunshine Coast
« Reply #24 on: August 19, 2014, 09:23:04 pm »
Ok I have got a bit of a problem.  The Motoplat flywheel needs a 28 x 1.25 internal thread.  I have tried a 28 x 1 puller with no luck.  They seem to be used on the later Rotax motors like ATKs.
If by chance you have one could I borrow it :P Unless someone can lend me one it looks like I will have to get one made.
« Reply #25 on: August 19, 2014, 09:30:40 pm »
you need a good thread man to whip one up phil whittle in Bendigo just did one for ol mates vespa, 27mm..
Offline KTM47
« Reply #26 on: August 20, 2014, 08:12:48 am »
Read the digital vernier properly 27.82 would be a 28 mm thread.  A good engineering (machine) shop could make a puller for it. But at $100.00 plus an hour it won't be cheap.
Offline VINDURO
    • VINDURO
« Reply #27 on: August 20, 2014, 09:48:52 am »
Noel,
Nice new project. Strange beast... never seen one of these before.
That puller is an odd size, 27mm x 1.25 is common enough however the 28mm is scarce.
I found one here: http://bit.ly/1rl38H3
And..... another one here:
http://www.trialsbits.co.uk/product_info.php?products_id=816
The UK might be your friend on this one.
Nice bike.
Jock
Offline Canam370
« Reply #28 on: August 20, 2014, 10:15:31 am »
Noel, I have a puller that should suit. PM me for details.
Offline gra1961
« Reply #29 on: August 21, 2014, 06:51:40 am »
i am pretty sure i have the flywheel puller and iam at nambour. give me a call on 0433407882 .cheers gregg
