Author Topic: TS185ER Forks  (Read 7712 times)
saint
TS185ER Forks
« on: June 15, 2014, 09:26:37 pm »
Were the Suzuki Ts185er forks the same diameter for the entire model history?
I found the early 80s models listed as 32mm, but were they ever 35mm later on?
Re: TS185ER Forks
« Reply #1 on: June 15, 2014, 09:48:04 pm »
All ER models (and US 80-81 models) 79 onwards are leading axle 33mm. 32mm and 35mm are incorrect.
Re: TS185ER Forks
« Reply #2 on: June 15, 2014, 09:56:00 pm »
I don't think they did change the fork size on the ER
The 185ER dont change much as the bike worked well for the marketing program.
Suzuki had other models to cater for people wanting change.
30mm
##TS-185 R/J/K/L/M/A/B “Sierra” (71-77)
32mm
##Suzuki
##DR-125 Z/D/E (82-84) 32 Suzuki GN-125 Z/D (82-83) 32 Suzuki GN-125 EM/EN/EP/ER/ES/ET/EV (91-97) 32 Suzuki SP-125 Z/D (82-83) 32 Suzuki TS-125 T/X (80-81) 32 Suzuki DS-185 N (79) 32 Suzuki DS-185 T (80) 32 Suzuki TS-185 N (79) 32 Suzuki TS-185 T/X (80-81)
35mm
Suzuki
RM-80 K/L/M/N/P (89-93)
RM-80 R/S/T/V/W/X/Y/K1 (94-01)
RM-100 N/T/X (79-81)
DR-125 G/H/J (86-88)
DR-125 SER/SES/SET (94-96)
RM-125 M/A (75-76)
SP-125 G/H/J (86-88)
DR-200 G/H/J (86-88)
DR-200 SET/SEV/SEW/SEX/SEY/SEK1/SEK2/SK3 (96-03)
RL-250 L/M “Exacta” (74-75)
SP-250 Z/D/F (82-83, 85)
TS-250 1 “Savage” (69)
TS-250 B/C/N (77-79)
GN-400 T/XT/XX/TX/TZ (80-82)
TM-400 K/L/M “Cyclone” (73-75)
GS-450 LD (83)
GS-450 LF/LG/LH/LJ (85-88)
GT-500 A/B “Titan” (76-77)
RE-5M, A
GS-550 LX/ LZ (81-82)
GS-550 B/C/EC (77-78)
GS-550 LN/LT (79-80)
GS-550 LG (86)
GT-550 J/K “Indy” (72-73)
GT-550 K (KAYABA)/ L (73-74)
GR-650 D/XD “Tempter” (83)
GS-650 EX/EZ(81-82)
GS-650 GLX/GLZ/GLD(81-83)
GS-750 B/C/EC (77-78)
GS-750 EX/EZ (81-82)
GS-750 LT/LX (80-81)
GS-750 TZ/TD (82-83)
GT-750 J/K/L/M/A/B “Lemans” (72-77)
http://organ-donor.org/motorcycle-data/fork-tube-diameter-list/#tube35
saint
Re: TS185ER Forks
« Reply #3 on: June 15, 2014, 10:02:41 pm »
Ok..............
Got my info re the early 80s 32mm from this list. http://scandalon.com/2009/06/motorcycle-fork-diameter-chart/
I'm looking buy a pair which the guy claims are TS185 and he's measured them as 35mm.
Just wanted to be sure before I commit......
saint
Re: TS185ER Forks
« Reply #4 on: June 15, 2014, 10:04:11 pm »
Thanks Pokey, you're the 185 guru.
Simo63
Re: TS185ER Forks
« Reply #5 on: June 15, 2014, 11:21:08 pm »
I've got a whole 80 model TS185 you can have for $500 Neil :)  Good runner as well :)
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: TS185ER Forks
« Reply #6 on: June 15, 2014, 11:22:30 pm »
TS250ER forks were 35mm, so as an experiment you could fit a set of TS250 triples and a DR250S (84-89) set of forks with the disc brake etc.  ;) ;) ;) ;) ;) ;) ;) ;) ;) ;)
Ban BLACK rims NOW
Re: TS185ER Forks
« Reply #7 on: June 15, 2014, 11:24:08 pm »
They are 33mm all the way through. The above site is wrong.
The ebay set are probably 82-84 DR250S (disc brake came in 85 model) if they are 35mm and someones changed them to that.  I take it you are looking at wreckers on ebay AU? Some have lot of stuff incorrectly listed. I have a application book that says 35mm and 32mm too but its incorrect. I saw this yrs ago when i went to order seals and they arrived as 32 and not 33mm. Yes my forks are original, i know the history of the bike and i  personally checked it with a good suzuki dealer. They said the forks never changed. Also last night i checked part numbers online for fork tubes and its still the same to 200? as i need a new set of tubes for mine as they are pitted between triples and new forks are cheaper than hardchrome these days.
TS250ER forks are 36mm not 35mm. I own this model too.Currently toying with the idea of putting the 36mm 250 front end on my 185 since my 250 is getting a differnt front end.
« Last Edit: June 15, 2014, 11:35:52 pm by LWC82PE »
saint
Re: TS185ER Forks
« Reply #8 on: June 16, 2014, 06:58:31 am »
I don't think the guy is a wrecker, but yes, they're on ebay.
I need a good set for my RL250...... (35mm)
Offline Doc
Re: TS185ER Forks
« Reply #9 on: June 16, 2014, 03:54:54 pm »
yup 35mm 82-84 DR250S forks will slip straight in the RL clamps. RL axle and wheels fit and they are also leading axle ;)
