Author Topic: Suzuki RV125 73??  (Read 33789 times)
Offline ninjamk
Re: Suzuki RV125 73??
« Reply #15 on: May 29, 2014, 04:41:07 am »
For tires, just get another rear wheel and bolt the front hub to it with some spacers.  Then you can run some modern atv tires.  Check out my post on http://www.2strokeworld.com/forum/index.php?topic=18332.msg138662#msg138662 for the details.  If you want, I have some spacers made, will just charge shipping.
Mitch
Bikes: 1972 TS/TM250, 2007 KLX300, 2016 GSX-S1000
Offline Colin Jay
« Reply #16 on: May 29, 2014, 06:09:43 pm »
I fought my way to the back of my shed this afternoon and checked the frame/engine number of my RV125. Number is 27922, so by the chart above that would make it a 1974 model.
Mine is yellow the same as your so there must have been a few yellow 74 models come to Aust.
I will follow your resto, it may just shame me into doing something with mine.
Offline Toolboy
« Reply #17 on: May 30, 2014, 02:45:18 pm »
RV125 is Alive
https://www.youtube.com/watch?v=5eviZLbUfVk&feature=youtu.be
Now to strip and restore
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Colin Jay
« Reply #18 on: May 30, 2014, 06:01:20 pm »
I liked the exhaust exiting from under the mid-section of the pipe in front of the rear wheel.
CJ
Simo63
« Reply #19 on: May 30, 2014, 06:15:34 pm »
I think they had a little blanking plate on the exhaust pipe there .. might be missing?
Offline Toolboy
« Reply #20 on: May 30, 2014, 06:40:49 pm »
The fumes were coming out of the seams of the pipe,,,looks like the muffler is blocked.
There is a half blanking plate on the exit of the rear pipe.
Can you cut off the muffler section and repack??
I should of taken a pic of the gear oil when I drained ,,,it looked like liquid milk chocolate
The clutch is jammed but I did ride down the street and shifts gears ok
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
« Reply #21 on: May 30, 2014, 06:55:03 pm »
The exhaust should be similar to the 185. removable repackable baffle. there is also a plug for draining whatever liquid gets in (yeah dropped my 90 in the surf one day)  right where the smoke was exiting on yours.
http://www.cmsnl.com/suzuki-rv125-1973-1977-usa_model16227/partslist/90980.html#results
Offline Toolboy
« Reply #22 on: May 30, 2014, 07:30:20 pm »
Thanks the diagram Pokey.
Had a look at my exhaust and found the problem
Hornet nest blocking outlet...geeeesh
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
« Reply #23 on: May 30, 2014, 08:38:58 pm »
That'd do It toolboy. I don't think anyone makes exhaust plugs in that shape.
 Ive started spraying everything in my bike hospital with a mixture of water and citronella oil as the mongrels get into everything.
 Good excuse to burn the muffler clean. I'll keep a look out on the horizon for smoke signals
Offline Toolboy
« Reply #24 on: May 30, 2014, 09:08:27 pm »
Col
What happened to the racing strip on your front and rear fenders.
The flared front fender on mine is that original?????
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Colin Jay
« Reply #25 on: May 31, 2014, 11:57:43 am »
Some where back before I got the RV it was given a respray, hence no racing strips on the guards. The flared bottom is correct, again, one of the previous owners modified the guard with a hacksaw by the feel of the cut edge on the guard.
CJ
« Reply #26 on: June 01, 2014, 11:32:20 pm »
A mate has NOS tyres for these, send me your tyre size and ph number.
Offline Toolboy
« Reply #27 on: June 02, 2014, 07:02:35 am »
PM sent Davey
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Toolboy
« Reply #28 on: June 11, 2014, 07:47:25 am »
Found another RV125....this one a 76 model.....
Will dismantle and build a great RV out of one then rebuild the second to sell
What I didn't see until bike arrived was welded gearshaft,,,,geeeeeeeeeesh
Test rode my 370 and 250Z at Kenilworth on Sunday,,,took the RV for a test ride :0)...needs work to holeshot,,,hahahah
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Toolboy
« Reply #29 on: June 11, 2014, 07:49:29 am »
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
