Author Topic: Interesting Monty Kicker.  (Read 5219 times)
« on: June 23, 2008, 06:12:24 pm »
http://cgi.ebay.com.au/MONTESA-CAPPRA-VR250_W0QQitemZ130232862082QQihZ003QQcategoryZ102690QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Montesa kickers must be a bit of a Monty weakness - I've got one damaged one and the ones on EvilPay are always hotly contested.
Whatcha reckon this one is? I reckon AT?CT1.
Re: Interesting Monty Kicker.
« Reply #1 on: June 23, 2008, 06:37:04 pm »
I think it's Montesa. Probably off of a Cota....
Ya wanta bet?
TooFastTim
« Reply #2 on: June 23, 2008, 06:45:04 pm »
You'll lose Ross. Definitely not off a Cota. Looks like a DT1 kickstart
« Reply #3 on: June 23, 2008, 06:46:32 pm »
Okay. Name your price....... 8)
Your VB360 for my VB360 ;D
« Reply #4 on: June 23, 2008, 06:47:35 pm »
Put ya money where ya mouth is Tim ;D I still reckon AT1/CT1.
« Reply #5 on: June 23, 2008, 06:54:27 pm »
I'll take that back Tim. When you look at the long shot it might be DT/RT1. The first angle looking down seems to shorten the kicker.
This is all good news, I've got at least one RT1 kicker and I think at least one other maybe two.
TooFastTim
« Reply #6 on: June 23, 2008, 07:02:14 pm »
I only said definitely not a Cota. That I would have put money on. But I won anyway  ;D
Offline paul
« Reply #7 on: June 23, 2008, 07:23:24 pm »
yep id have to agree with that
TooFastTim
« Reply #8 on: June 23, 2008, 07:46:52 pm »
Swively bit on top is the same as any other Cappra/Cota kicker. In the pic posted above it's very different.
You mob got me thinking, the Cota 247/348/349 (up to the white wonders) kickers were the same as the Cappras (swivel at the top, mushroom around the shaft, see pic http://solomontesa.com/tienda/images/palaarranmonp_69.jpg). The last 349 was different. The whole kicker swiveled from the splines, no mushroom. The Cota 350 (last 349 with red mudguards) was the same. I can't remember the Cota 330/335 kicker but I'd assume the same as the 350. The 123/172/200/242/304/307/309/310's (same bottom end as the 125 Cappra) would have used the same as the Cappra 125. Swivel at the top, but a slight kink just above the splines leading to 45deg angle and no mushroom.
I'm no expert on Cappras but I do know my Cotas having owned a few.
Jeezus. I need to ge a life.
« Last Edit: June 23, 2008, 07:51:29 pm by TooFastTim »
« Reply #9 on: June 23, 2008, 10:47:50 pm »
Just as a side note, has anyone looked at what he's using for a fuel TAP!!
Yep ::) ;D
« Reply #10 on: June 24, 2008, 09:42:42 am »
This is the same bike that was advertised in the for sale section a few months back. The owner had not started it at the point, although explained that he was told the motor was good. The ebay description is still sought of ambiguous in that it doesn't really state how the bike runs & rides. Looks like a decent bike with a few minor glitches as usual with old bikes, no doubt it could tell some stories if it could talk. I hope it goes to a good home.
« Reply #11 on: June 24, 2008, 09:58:48 am »
This orphanage is full ;D.
He would have been popular with his neighbours starting that bike at anytime - I bet it has a good crackle to it ::) :P.
It will be interesting to see if it sells - I think its over the market. But there's one way to find out for sure ;D.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #12 on: June 24, 2008, 10:39:54 am »
DT1,2,3/RT1,2,3 kicker for sure!
AT/CT is straight with no bend.
fancy that hey, a yamaha part to the rescue...
"flat bickie"
Offline JC
« Reply #13 on: July 12, 2008, 06:15:15 pm »
I'd say its definitely Yam, but not sure what model. (I would have thot small-bore not DT/RT1 which had larger shaft) It looks at first like a Monty one but its not. The spring under the fold-out part is a dead give-away for Yamahe (or at least japanese)
