Author Topic: Starting problems..  (Read 12494 times)
Offline VMX Andrew
Starting problems..
« on: April 14, 2014, 07:01:01 pm »
Having problems starting my 77 AW400.
Checked the spark while kicking with new plug and cant see any flame while its touching the top of motor.
So im thinking it could be the coil ??
Has anyone got a spare coil laying around or should I get it tested first then start looking elsewhere ??
Don't really wanna fork out $500 for a new PVL ignition kit :o
Cheers Andrew.
HeavenVMX
Re: Starting problems..
« Reply #1 on: April 14, 2014, 07:31:45 pm »
It could be the coil but what you are describing is a typical failure of a motoplat through age. The stator coils break down and the spark gets weaker and weaker particularly at kick speed. The other symptom is frequent plug fouling as the spark energy even at operating speed is way down. Send the whole thing to small coil rewinds or Betta Bikes for a rewind.
Or go the PVL
Umm when you say flame I assume (bad word) you mean spark or are you trying to burning because it won't start?
Offline VMX Andrew
« Reply #2 on: April 14, 2014, 07:46:04 pm »
Oops I should have said SPARK.
Yes I couldn't see any spark while the plug was sitting on top of the motor.
Thanks for the info Greg I will look into all those options you have given me
but $500 for new PVL......  :'(  OUCH
Offline paul
« Reply #3 on: April 14, 2014, 08:15:49 pm »
Just chech the wires and conections on the coil ,also the points ,that bike use to loose spark after it had been either been washed or wet , ;D
Offline paul
« Reply #4 on: April 14, 2014, 08:21:49 pm »
Also I might still have a few maico coils
Offline VMX Andrew
« Reply #5 on: April 14, 2014, 08:37:18 pm »
Thanks Paul for that info, will check everything tomorrow.
Cheers Andrew.
Offline bazza
« Reply #6 on: April 14, 2014, 08:51:36 pm »
As Paul said, have you tried a couple of plugs?
Embrace patina
Offline GD66
« Reply #7 on: April 14, 2014, 09:20:12 pm »
And the earth...
Offline Ktm181
« Reply #8 on: April 14, 2014, 10:03:56 pm »
And the earth...
AND disconnect the kill switch, faulty switches have been a common cause AND try a NEW spark plug, you'd be amazed how many I have seen with a simply failed plug or shorting kill switch.
cheers,
Wayne.
Offline Tossa
« Reply #9 on: April 14, 2014, 10:05:31 pm »
My 74 Husky Mag 250 shows no sign of spark when I try to start it.  Flood the Bing carby 7-8 kicks, remove plug, squirt of Start Ya Bastard and starts very easily.  Damn Motoplat are so strange
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
« Reply #10 on: April 14, 2014, 10:31:29 pm »
and from the yellow camp....new pistons too small ,so compression's up to mud..
Process of elimination.   :P
Hope its an easy one Andrew  :)
Offline 09.0
« Reply #11 on: April 16, 2014, 10:49:22 am »
To start with you say you have a pvl, so the motoplat call is irrelivent.
A bad earth between the frame and motor is a common one. The frame gets surface rust on it.
First thing that fails on a pvl is the stator windings.
HeavenVMX
« Reply #12 on: April 16, 2014, 12:24:31 pm »
Don't really wanna fork out $500 for a new PVL ignition kit :oCheers Andrew.
It says he does not really want to fork out for a new PVL I read that as he does not have a PVL but could be wrong
« Last Edit: April 16, 2014, 12:35:40 pm by HeavenVMX »
Offline VMX Andrew
« Reply #13 on: April 16, 2014, 06:38:59 pm »
Sorry for the confusion fellas I should have stated that the coil is a motoplat item
and yes $500 is a bit steep for a new PVL item but anyways I still haven't got around
testing the wires for earthing.
Have been too busy at work will have a look over the weekend.
Thanks Andrew.
Offline Ted
« Reply #14 on: April 16, 2014, 06:44:02 pm »
You have removed the spark plug cap, bared the coil wire back, earthed it and given it a kick haven't you.
81 YZ 465 H   77 RM 125 B
