Author Topic: Length of a standard YZ125G Gudgeon Pin  (Read 4180 times)
Simo63
« on: April 14, 2014, 03:02:13 pm »
As the title says, I am looking to confirm the length of a standard YZ125 Gudgeon Pin.
Do they increase in size as the piston oversize increases?
Can anyone help?
Simo
Re: Length of a standard YZ125G Gudgeon Pin
« Reply #1 on: May 13, 2014, 01:34:58 am »
don't know the length but it would be easy to work out from your old piston but no increase in length for oversize pistons though
« Reply #2 on: May 14, 2014, 12:42:56 pm »
The length doesn't change with OS's. I could get you the length of a Wiseco pin if that helps.
If you have the stock piston the pin will be about .5mm shorter than the distance between the insides of the clip grooves.
