Marque Remarks
Yamaha
Length of a standard YZ125G Gudgeon Pin
Topic: Length of a standard YZ125G Gudgeon Pin (Read 4182 times)
Simo63
April 14, 2014, 03:02:13 pm »
As the title says, I am looking to confirm the length of a standard YZ125 Gudgeon Pin.
Do they increase in size as the piston oversize increases?
Can anyone help?
Simo
TT5 Matt
Re: Length of a standard YZ125G Gudgeon Pin
May 13, 2014, 01:34:58 am »
don't know the length but it would be easy to work out from your old piston but no increase in length for oversize pistons though
sleepy
May 14, 2014, 12:42:56 pm »
The length doesn't change with OS's. I could get you the length of a Wiseco pin if that helps.
If you have the stock piston the pin will be about .5mm shorter than the distance between the insides of the clip grooves.
Marque Remarks
Yamaha
