Author Topic: Studs  (Read 6618 times)
Offline Digga
Studs
« on: March 30, 2014, 11:16:30 am »
Any good tips out there on how to remove stubborn studs out of the cases/cylinder joint?
1977 Yamaha YZ250D, 1977 Yamaha YZ400D, 1980 Yamaha YZ125G
Re: Studs
« Reply #1 on: March 30, 2014, 12:28:51 pm »
use a proper stud removing tool that joins to a half inch drive ratchet  its the only way to do it properly . Iain
Offline Digga
Re: Studs
« Reply #2 on: March 30, 2014, 12:59:32 pm »
Thx Iain, where do you get these from?
Re: Studs
« Reply #3 on: March 30, 2014, 01:17:05 pm »
also pre lube with a releasing agent of choice ;) ie yeild, penetrene, super releasing agent Reducteur H-72
Re: Studs
« Reply #4 on: March 30, 2014, 01:37:48 pm »
Also consider small amount of heat in conjunction with above, Cheers J
Re: Studs
« Reply #5 on: March 30, 2014, 02:07:09 pm »
;) yep and with a short sharp shock or a luv tap :) depending what music your into :o
Re: Studs
« Reply #6 on: March 30, 2014, 02:23:22 pm »
most good tool shops will have them or an engineering shops . will post a photo later . Iain
Re: Studs
« Reply #7 on: March 30, 2014, 02:37:31 pm »
hope this helps if your going to take out studs do it properly as vice grips or multi grips will slip and f up your job . $25 odd bucks . Iain
« Last Edit: March 30, 2014, 02:42:10 pm by iainyz »
Offline smed
Re: Studs
« Reply #8 on: March 30, 2014, 03:45:30 pm »
They are OK but I prefer this type, http://www.ebay.com.au/itm/STAHLWILLE-12617-3-roller-6mm-Stud-Remover-German-Made-New-/301121388934    You can only use them on the one size though ;) unlike Ians one,you can also get them in kits with 3 or 4 different sizes :)
Offline kdx 175
Re: Studs
« Reply #9 on: March 30, 2014, 03:47:56 pm »
15 $ for it 41$ post thats nuts
Re: Studs
« Reply #10 on: March 30, 2014, 03:59:11 pm »
Yeh $41 for a thing the size of a plug socket . How the hell do they get these prices . Iain
Offline Digga
Re: Studs
« Reply #11 on: March 30, 2014, 05:18:11 pm »
Thx everyone, I will head tomorrow & do some toolshopping  ;)
Re: Studs
« Reply #12 on: March 30, 2014, 05:39:44 pm »
The one Smed showed is the one I use. It paid for itself the first time I had to remove a stubborn square barrel Maico stud (Anyone who's ever owned a squarie Maico will know what I mean ;D)
STAHLWILLE 12617 3-roller 6mm Stud Remover, German Made, New!
Re: Studs
« Reply #13 on: March 30, 2014, 06:11:07 pm »
Bought a Stahlwille 6 -8 and 10 mm stud remover set from one tool stalls "specials  aka  chuck out bin" at last years Elmore Field days to replace my old dunger unit. Cost $12... ya scounge around and sometimes it pays :)
Offline smed
Re: Studs
« Reply #14 on: March 30, 2014, 07:32:44 pm »
I was just showing the type of tool,not that one though the shipping price is all f**ked up,any good tool shop should have em or can get em ;)
