Author Topic: cr125m footpegs  (Read 21655 times)
090
cr125m footpegs
« on: August 21, 2007, 07:57:31 pm »
I have just fitted a set of aftermarket crf50 footpegs(nice and wide) from a adult mini racer.They bolt straight up using crf50 return springs as well.Also tapered steering head bearings which are available aftermarket for crf50 also fit
Re: cr125m footpegs
« Reply #1 on: August 21, 2007, 08:16:38 pm »
nice find !
Offline DJRacing
  • YZ125X
Re: cr125m footpegs
« Reply #2 on: August 21, 2007, 08:35:57 pm »
090 what size headset bearings? outside diameter and depth of the race? I would like to fit tapered bearings into a couple of my old YZ's
090
Re: cr125m footpegs
« Reply #3 on: August 21, 2007, 08:52:05 pm »
Bearings are and have been in bike for a few months, i have ordered another set though and will take some measurements for you.
Re: cr125m footpegs
« Reply #4 on: August 21, 2007, 09:07:41 pm »
What sort of money did you pay for the footpegs Brad?
I've got some biggish aftermarket pegs on my 84 YZ, and I love them, but at $100+ per pair it's gonna be a damn long time before I can afford them for (even) the bikes I take seriously as race bikes.
Offline DJRacing
  • YZ125X
Re: cr125m footpegs
« Reply #5 on: August 21, 2007, 09:11:14 pm »
Thanks 090 its always good to find modern parts like that to fit the old bikes
Offline DJRacing
  • YZ125X
Re: cr125m footpegs
« Reply #6 on: August 21, 2007, 09:16:02 pm »
Nathan I was looking at replacing some of my pegs on some of my YZs and my parts man and I thought that newer YZ pegs could fit (about '96 or so) but we never followed through with it. Maybe I should look into it again. The geniune (yz '96) pegs were cheaper than after market and were bigger than the older pegs
090
Re: cr125m footpegs
« Reply #7 on: August 21, 2007, 09:28:46 pm »
Yeah Nathan, these are the expensive ones also, but seeing as the Chinese bikes mold themselves from a crf50 you could get a cheaper set through the china bike route. I shall keep you informed DJ.
Offline caps 999
Re: cr125m footpegs
« Reply #8 on: August 22, 2007, 07:16:39 am »
ballards make foot pegs for the 82 yzs
MUGEN power
Offline dkupf
  • Kinka Beach Qld
Re: cr125m footpegs
« Reply #9 on: August 22, 2007, 09:13:34 am »
I've got yz426f on my 125m1 had to grind 1/4 inch off the pegs and drill the holes out in the frame and they work well. Darcy
Offline YZ250H
  • Back in QLD Baby !
Re: cr125m footpegs
« Reply #10 on: August 22, 2007, 09:22:06 am »
DJ,
I haven't tried it myself, but I have heard of others using 01-04 YZ/YZF pegs on early (our model) YZ's.  There is a bit of a difference in the mounting bolt size (probably better to shim the old (smaller) bolt than drill out the metal on the mounting bracket).  There is a bit of fiddling with the spring as well as it is a bit big with 3 turns on it to go inside the old mounting.  Project YZ put '94's on his, but I am told the later ones work better.
Just an idea ............ ::)
Quicksilver
Re: cr125m footpegs
« Reply #11 on: August 22, 2007, 09:35:56 am »
Brad.
Could you post a pic of the pegs mounted on the CR..
090
Re: cr125m footpegs
« Reply #12 on: August 22, 2007, 12:21:51 pm »
Here you go. No modification necessary.
Offline DJRacing
  • YZ125X
Re: cr125m footpegs
« Reply #13 on: August 22, 2007, 01:34:01 pm »
They look fanastic 090, you wont be getting on her without boots on, unless ya like grated feet :D
090
Re: cr125m footpegs
« Reply #14 on: August 22, 2007, 05:45:52 pm »
For sure! No worse feeling than your feet slipping off your pegs...except maybe going over the bars
