Author Topic: Broken Fin  (Read 7837 times)
Offline kdx Geoff
Broken Fin
« on: February 25, 2014, 11:08:36 am »
l have a small piece of fin missing and looking for ideas to make it look right. . Making a piece to fit in seems pretty straight forward but having stay in place......    lm going to paint the engine after the repair.
Offline Stewart Allen
Re: Broken Fin
« Reply #1 on: February 25, 2014, 11:32:03 am »
I'd just use devcon, & use plastic or something to shape until it hardens then dress it up with a file, coat of gravy all good.
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
Re: Broken Fin
« Reply #2 on: February 25, 2014, 01:58:19 pm »
tig weld a donour peice in  ;) then done and dusted all proper like
looks fresh have ya got the missing bit off the jig saw?
Re: Broken Fin
« Reply #3 on: February 25, 2014, 03:37:48 pm »
Not a big piece missing from what I can see, build it up with a few beads on the tig & file it back to shape
Re: Broken Fin
« Reply #4 on: February 25, 2014, 05:11:20 pm »
Yep I would go with that ;) ;D
Offline kdx Geoff
Re: Broken Fin
« Reply #5 on: February 25, 2014, 08:10:04 pm »
Thanks blokes
option 1 seems the simple fix  :)
Re: Broken Fin
« Reply #6 on: February 25, 2014, 11:44:46 pm »
Devcon is probably your simple fix, personally I would weld it but then I'm biased.
The missing piece is irrelevant as it is much easier to fill the cavity than try to hold a small piece in place and get penetration both sides.
I would just pitch the broken piece when you weren't looking ;D and build it up with weld.
Down side is you would need to take the barrel off for welding and for the perfect finish you would want to blast with a course garnet to get the cast texture back before painting as the patch would be smooth after sanding back.
Re: Broken Fin
« Reply #7 on: February 27, 2014, 11:46:12 am »
Agree ;) the best way is not allways the easiest
Offline Ktm181
Re: Broken Fin
« Reply #8 on: February 27, 2014, 06:39:26 pm »
Hi Geoff, sorry I should have read this earlier.  YOu could shape your piece and then some sort of metal glue will work fine. Some years and about 5000 miles back in used adhesive to repair the casting on a Z900 cyl head, tach drive part of the casting was broken off and still bolted to the cable, I just scrubbed it all with white spirits, mixed the adhesive up and put it back on, its still there with the cable running through it and bolted to it, your fin piece will stay for ever.
Just find a damaged barrel of similar metal and remove a piece so looks same, file to shape wack it on my friend. Easy. No load on it at all.
Let me know if you want me to chase up the brand of adhesive, I borrowed it from my local mc shop, Mick Dyers in Penrith, good bloke with a LOT of experience.
Kt.
Re: Broken Fin
« Reply #9 on: February 28, 2014, 04:09:09 pm »
just find a damaged barrel........ ???
Re: Broken Fin
« Reply #10 on: February 28, 2014, 05:29:47 pm »
He's in luck, he already has one  ;D
Offline Lewis
Re: Broken Fin
« Reply #11 on: February 28, 2014, 05:37:02 pm »
GMC,hehehe,I was thinking the very same thing.
Re: Broken Fin
« Reply #12 on: February 28, 2014, 05:58:11 pm »
whats worse than a broken fin?
A bruised pol
Re: Broken Fin
« Reply #13 on: March 01, 2014, 12:31:36 pm »
you cant get in without a tie...bugger ive bought a Cambodian instead
Offline Ktm181
Re: Broken Fin
« Reply #14 on: March 01, 2014, 01:17:16 pm »
kT.
In fact I reckon he has SEVERAL!!!
