Clubroom
Tech Talk
honda cr 250 chain lowering bracket
Topic: honda cr 250 chain lowering bracket (Read 2788 times)
LeighW
C-Grade
February 11, 2014, 07:32:02 pm »
anyone put me onto a good cnc machine shop in melb need to make a chain lowering bracket for my cr 250 1980 cheers leigh
Lozza
Re: honda cr 250 chain lowering bracket
February 11, 2014, 11:20:57 pm »
Rick Williams
Ideal Engineering Solutions P/L
13 Halley Crescent Campbellfield Vic 3061
Mb : 0409 742 590
E : rick.idealengineeringsolutions @ gmail.com
Tell Rick I sent you
bigk
Kangaroo Flat Victoria
February 12, 2014, 08:08:35 am »
That's a simple little bracket which would take about 1/2 an hour doing it nicely by hand, CNC machining seems way overkill & probably expensive for one unit. I'm sure I have a pattern here somewhere.
bazza
February 12, 2014, 09:53:08 am »
why do you need to lower?
LeighW
C-Grade
February 12, 2014, 01:37:40 pm »
I need to lower the roller because iv put a pfr arm on and being thicker when the chain is on there is not enough clearance between the roller and the swingarm in the std position
bigk
February 13, 2014, 08:13:24 am »
There are other options if you don't want to use the lowering bracket way.
Rossvickicampbell
February 13, 2014, 09:36:54 am »
Leigh - not sure if I mentioned and not sure if it is sutiable for your swingarm but for $75 I think it is (not sure there either - early start to the day) Karl Landrus makes one - might be easy enough to fit?
LeighW
C-Grade
Reply #7 on:
February 13, 2014, 02:28:45 pm »
thanks ross did order one from him paid didn't turn up put a claim in it got ugly real quik and not from my end cheers leigh
Rossvickicampbell
Reply #8 on:
February 13, 2014, 04:57:58 pm »
Leigh - not surprised - lets say I wouldn't spend big bucks for a swingarm with him again - sorry to hear.
Clubroom
Tech Talk
