Author Topic: honda cr 250 chain lowering bracket  (Read 2780 times)
Offline LeighW
« on: February 11, 2014, 07:32:02 pm »
anyone put me onto a good cnc machine shop in melb need to make a chain lowering bracket for my cr 250 1980 cheers leigh
Re: honda cr 250 chain lowering bracket
« Reply #1 on: February 11, 2014, 11:20:57 pm »
Rick Williams
Ideal Engineering Solutions P/L
13 Halley Crescent Campbellfield Vic 3061
Mb : 0409 742 590
E : rick.idealengineeringsolutions @ gmail.com
Tell Rick I sent you
« Reply #2 on: February 12, 2014, 08:08:35 am »
That's a simple little bracket which would take about 1/2 an hour doing it nicely by hand, CNC machining seems way overkill & probably expensive for one unit. I'm sure I have a pattern here somewhere.
Offline bazza
« Reply #3 on: February 12, 2014, 09:53:08 am »
why do you need to lower?
Embrace patina
Offline LeighW
« Reply #4 on: February 12, 2014, 01:37:40 pm »
I need to lower the roller because iv put a pfr  arm on and being thicker when the chain is on there is not enough clearance between the roller  and the swingarm in the std position
« Reply #5 on: February 13, 2014, 08:13:24 am »
There are other options if you don't want to use the lowering bracket way.
« Reply #6 on: February 13, 2014, 09:36:54 am »
Leigh - not sure if I mentioned and not sure if it is sutiable for your swingarm but for $75 I think it is (not sure there either - early start to the day) Karl Landrus makes one - might be easy enough to fit?
Offline LeighW
« Reply #7 on: February 13, 2014, 02:28:45 pm »
thanks ross did order one from him paid didn't turn up put a claim in it got ugly real quik and not from my end cheers leigh
« Reply #8 on: February 13, 2014, 04:57:58 pm »
Leigh - not surprised - lets say I wouldn't spend big bucks for a swingarm with him again - sorry to hear.
