Author Topic: Thrust Washers  (Read 4287 times)
Offline Neilio
Thrust Washers
« on: January 31, 2014, 05:20:00 pm »
After some advice, have popped the cylinder off the RM400T and lo and behold there are no thrust washers between the big end of the rod and the crank.
I've looked at the parts diagrams for that model on the cmsnl website and it shows thrust washers however there is no sign of them and a good friend who is also a very experienced mechanic says that he used to own another Suzuki that didn't have thrust washers and said that the rod looked like it was possibly designed to control thrust using the piston.
To me that seems odd given what the parts diagrams show.
So I was hoping if someone could set me straight on whether or not thrust washers are actually needed or not.
Re: Thrust Washers
« Reply #1 on: January 31, 2014, 06:38:37 pm »
That's how those Suzuki cranks are, the thrusts are quite small and on the sides....I thought the same on the first one I saw.
Offline matcho mick
    • Moto Tumbi
Re: Thrust Washers
« Reply #2 on: January 31, 2014, 06:48:31 pm »
pretty common with suzy's,using the piston to centralise the b/end,think of all the oil going into that gap,works for me  :D, :P
Re: Thrust Washers
« Reply #3 on: February 01, 2014, 09:11:13 am »
They should be  there  ;)
Part # = 09160-24014
Part Description = WASHER (24X29X2)
Model Count = 12
GT750-B 1977 738 GT750 LEMANS STREET
GT750A 1976 738 GT750 LEMANS STREET
GT750J 1972 738 GT750 LEMANS STREET
GT750K 1973 738 GT750 LEMANS STREET
GT750L 1974 738 GT750 LEMANS STREET
GT750M 1975 738 GT750 LEMANS STREET
PE400T 1980 397 PE400 DUAL PURPOSE
PE400X 1981 397 PE400 DUAL PURPOSE
RM250-N 1979 246 RM250 OFF ROAD
RM250-T 1980 246 RM250 OFF ROAD
RM400N 1979 417 RM400 OFF ROAD
RM400T 1980 417 RM400 OFF ROAD
Offline Neilio
Re: Thrust Washers
« Reply #4 on: February 02, 2014, 09:28:41 pm »
You're right Davey Crocket, they are there, just very small!
Re: Thrust Washers
« Reply #5 on: February 03, 2014, 04:21:53 pm »
Unlike say Yamaha, Suzuki dont give a tolerance for rod to crank , they give a Rod deflection tolerance, but for me I would make sure it all comes upto specs, and if ie its not the standard rod (is a std suzi rod) would check the rods big end width and compare to the original Suzi and would put thrust washers in to suit.
Offline davidmc
Re: Thrust Washers
« Reply #6 on: February 03, 2014, 05:04:19 pm »
Suzuki often use thrust washers on the little end (piston pin)
