Author Topic: NEED HELP ON 3 YAMAHA MOTORS  (Read 8797 times)
« on: August 20, 2007, 03:47:16 pm »
hi
i have just recived 3 yamaha motors
450-228728 in peices
3j5-00608   in peices
dt1f-123327 complete
can any one tell me what they are
jimg
Re: NEED HELP ON 3 YAMAHA MOTORS
« Reply #1 on: August 20, 2007, 04:44:52 pm »
450 is a 1975 - DT250 if you dont need it get onto freaky he has a use for them.
3J5 ?  is that  a yamaha orare you misreading it ? unless its a late model DT or one of them 79 DT 400 F plonkers
Dt1F is from a DT2 1972 series
« Last Edit: August 20, 2007, 07:20:28 pm by Freakshow »
« Reply #2 on: August 20, 2007, 06:33:39 pm »
hi
it could be 305
the barrel has a place for decompresion lifter i think it might be 400cc
jimg
« Reply #3 on: August 20, 2007, 06:58:42 pm »
450 prefix can also be '74 DT250 (and maybe twin shock '76?). The actual serial number tells you which year, but I can't remember what the change-over number is.
Other way to tell is the cylinder head - '74 has parallel fins, '75 has radial fins.
Speed and Sport shows no matches for 3J5 or 3O5.
305 prefix is LT2, which you wouldn't mistake for a 400cc engine!
Most barrels will have the capacity cast into them, which would help.
Pics?
« Reply #4 on: August 20, 2007, 07:09:55 pm »
1974 cut off is prior to the 20000 numbers so its late 75 build
:DT250B Year: 1975 Start Engine#: 450-200101 +
« Last Edit: August 20, 2007, 07:17:13 pm by Freakshow »
« Reply #5 on: August 20, 2007, 07:21:24 pm »
ok IF IT HAS A DECOMP SPOT IT WILL BE A  ::: DT 400 F 79 = 3J5  ::
