Author Topic: Alloy Rims, how much corrosion is too much ?  (Read 3956 times)
Offline kdx Geoff
« on: January 01, 2014, 07:36:18 pm »
30 year old alloy rim, I've cleaned it up a bit and it feels solid......
If this is serviceable, how should a treat it to stop further deterioration.
kdx Geoff
Re: Alloy Rims, how much corrosion is too much ?
« Reply #1 on: January 01, 2014, 07:44:34 pm »
That's probably fine. Pick/chip out the splinters and make an assessment from there.
I've seen rims with MUCH worse corrosion, and they'd been holding up fine to some hard use.
To protect it further, get rid of all the loose stuff and just paint it.
Offline kdx Geoff
« Reply #2 on: January 01, 2014, 07:51:30 pm »
Thanks Nathan
Offline AdamN
« Reply #3 on: January 01, 2014, 07:53:15 pm »
This is probably too much :o
Adam
'82 PE175Z, '92 YZ125D1, '93 WR500ZE, '13 KTM350EXC-F, '16 Husky TE300
Offline bazza
« Reply #4 on: January 01, 2014, 07:55:36 pm »
buff or wire out on inside and coat of ally paint?
Bloody cow turds not washed off does that to the good side
Embrace patina
Offline Lewis
« Reply #5 on: January 01, 2014, 08:49:34 pm »
Geoff,I'd be inclined to tidy it up with a quick blast if glass bead,see if Perrows can offer some advice on a treatment otherwise a coat of etch primer may be enough.
Offline kdx Geoff
« Reply #6 on: January 01, 2014, 08:56:19 pm »
Going to do that Lewis but...... it wont fit in the cabinet ;D Wire brush will do.
Offline Lewis
« Reply #7 on: January 01, 2014, 09:10:26 pm »
cut it in half then it'll fit.
« Reply #8 on: January 02, 2014, 11:20:35 am »
wire wheel will do a good job
