Author Topic: best way to cut/shape seat foam  (Read 24685 times)
« on: December 24, 2013, 02:03:48 pm »
for a lovely smooth finish ;)
Re: best way to cut/shape seat foam
« Reply #1 on: December 24, 2013, 02:57:00 pm »
Electric carving knife to start with, then an orbital sander
« Reply #2 on: December 24, 2013, 03:15:40 pm »
AHH HA good stuff ;) hey what grade paper ??? I guess number 1 house brick (coarser the better)? thanx.   :)
« Reply #3 on: December 24, 2013, 03:22:03 pm »
hey what grade paper? grab a selection of course , medium and fine Shelpi and have a test on the foam. Have found over the years a fair bit of variance. ;)
« Last Edit: December 24, 2013, 09:22:02 pm by Tim754 »
« Reply #4 on: December 24, 2013, 03:22:14 pm »
I used a hand linisher with good effect
« Reply #5 on: December 24, 2013, 03:26:47 pm »
hey what grade paper? grab a selection of course , medium and fine Shelpi and have a test on the foam you. Have found over the tears a fair bit of variance. ;)
Ah Ha roger wilc oh wise one ;)
« Reply #6 on: December 24, 2013, 03:30:20 pm »
A hand linisher hey :) disc or belt ??? ie would a belt sander do  :P and do you a variety of course grades?
« Reply #7 on: December 24, 2013, 06:20:42 pm »
Its an a attachment you can purchase which fits onto your angle grinder runs 25mm belts.
Offline SON
« Reply #8 on: December 24, 2013, 06:25:46 pm »
Flap disc the best by far
GT43
« Reply #9 on: December 24, 2013, 08:43:00 pm »
Can I ask where to get good firm foam from ?
Clarke rubber perhaps ?
Sorry to deviate your thread a little Shelpi.
Offline Matador107
« Reply #10 on: December 24, 2013, 08:59:30 pm »
Clark rubber. They have various types of density available.
Bultaco Metralla, Matador MK 5, Montadero mk2, El Bandido model 18,plus lots of bits and two Honda XR's 250,350.
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #11 on: December 25, 2013, 09:14:27 am »
I use an electric bread knife to first get the foam into the shape I want. Then I use my belt sander with #60 Grade belt to carefully finish off the foam. Then I stretch and glue a thin polyester material over the foam using spray contact adhesive. I learnt this method from an upholsterer years ago.
I've never been able to find dense enough foam at clarke rubber. I'd be interested to know what clarke store stocks high density foam...
« Reply #12 on: December 25, 2013, 09:29:08 am »
I give it to an automotive trimmer. It's so easy.
« Reply #13 on: December 25, 2013, 09:58:56 am »
ah dont be sorry ;) GT43 its all in the name of us all getting the perfect seat for our sorry arses ;D
in the past Iv'e managed to do a passble job but just knew the guru's here would supply perfection ;)
« Reply #14 on: December 25, 2013, 10:07:44 am »
luv it, ok now all we need is to locate high dens, then I will be able get what I want how I want when I want ;) :) :D ;D Merry christmas chaps oh and chapets
