Author Topic: Clutch basket: IT250,IT465,YZ465 IT465  (Read 10159 times)
Offline Alisdair
« on: December 20, 2013, 11:56:30 am »
After a clutch basket for a IT465H, believe the listed models below fit.
Please reply here or Email [email protected] if you have one for sale
Located Brisbane, Queensland
IT250H - 1981 Assembly: CLUTCH PRI DRVN GEAR (63T) (SKU: 3R4-16150-00-00)
IT250J - 1982 Assembly: CLUTCH PRI DRVN GEAR (63T) (SKU: 3R4-16150-00-00)
IT465H - 1981 Assembly: CLUTCH PRI DRVN GEAR (63T) (SKU: 3R4-16150-00-00)
IT465J - 1982 Assembly: CLUTCH PRI DRVN GEAR (63T) (SKU: 3R4-16150-00-00)
YZ465G - 1980 Assembly: CLUTCH PRI DRVN GEAR (63T) (SKU: 3R4-16150-00-00)
YZ465H - 1981 Assembly: CLUTCH PRI DRVN GEAR (63T) (SKU: 3R4-16150-00-00)
YZ250G - 1980 Assembly: CLUTCH YZ250G - H PRI DRVN GEAR (63T) (SKU: 3R4-16150-00-00)
Offline LeighW
Re: Clutch basket: IT250,IT465,YZ465 IT465
« Reply #1 on: December 21, 2013, 03:19:03 pm »
east coast vintage has them new [billet] about 500$
Offline Alisdair
« Reply #2 on: December 24, 2013, 11:27:37 am »
Thanks for the reply mate
Too much for me at the moment, was really hoping to get something a lot cheaper.
Offline Alisdair
« Reply #3 on: December 27, 2013, 08:50:27 pm »
Still looking
Offline Ted
« Reply #4 on: December 28, 2013, 03:50:13 am »
While parts for a 465 are readily available the two parts you will find unobtainable are clutch baskets and shift forks.
Seven years ago when I built my 465 I bought a trick billet one new from the UK. I cannot recall who they were but they advertised in VMX mag years ago. Check or ask if someone knows who they were. Start your search eight years ago up till say four years ago.
East coast vintage may be your only option
81 YZ 465 H   77 RM 125 B
Offline Alisdair
« Reply #5 on: December 31, 2013, 01:33:26 am »
Thanks for the reply.
I guess I better start saving up then.
Why are they unobtainable?
Common problem with them?
Offline Ted
« Reply #6 on: January 01, 2014, 03:57:26 pm »
No prob with them. These bikes are over 30 years old. Raced for one maybe two years and then farm hacks after that.
These bikes were designed to be raced for one year only. Just to have some part of them running now is a plus.
You can always buy a complete motor and take a punt on the basket. See if you can inspect it first
Good luck.
« Reply #7 on: January 01, 2014, 04:08:26 pm »
How much money have you got to spend?
http://www.eastcoastvintagemx.com/new---billet-parts.html
Offline Ted
« Reply #8 on: January 01, 2014, 05:08:20 pm »
Even when you buy these billet baskets you still have to fu...koff the rivets and thru bolt using the best adhesive ( loctite etc ) you can find. Best to do this before installation. Then you will have something that will outlast you.
Offline Alisdair
« Reply #9 on: January 05, 2014, 02:27:16 am »
Still looking
Offline Husky500evo
« Reply #10 on: January 05, 2014, 05:46:17 am »
I think that I have a complete clutch for an IT465. But I am away with work at the moment and won't be able to post some pics of it until about Thursday.
Offline Alisdair
« Reply #11 on: January 06, 2014, 03:18:54 am »
 Husky500evo
It would be great if you could, I would appreciate it soo much. :D
Really want to get this bike back on the trails.
Offline Husky500evo
« Reply #12 on: January 09, 2014, 09:08:10 am »
Here is my IT465J clutch. It appears to have no cracks or damage other than the grooves worn in the fingers of the basket, that you can see in the picture, from the tags on the clutch plates. You could file these down if it made the clutch action notchy, but I would leave them alone if the clutch works ok. I think these alloy fingers on the basket eventually break, which is why second-hand baskets are hard to find. I would want $120 for the basket, plus postage, but would throw in the rest of the clutch as well if you wanted it. Let me know if you are interested and I will take it to the post office to get a postage cost.
Offline Husky500evo
« Reply #13 on: January 09, 2014, 09:26:20 am »
Here is a pic of the back of the IT465 clutch basket  I am sure that I have another basket somewhere that came off my YZ465H race bike from back in the day. It had a damaged helical ring gear, that was caused by the nut holding the primary drive gear coming loose from the end of the crank. If I can find it, I might be able to drill out the rivets and fit another ring gear on that one, as the alloy basket was still good.
Offline Alisdair
« Reply #14 on: January 09, 2014, 11:05:49 am »
Hey mate, I will take it all, I'll send you my address via the a message on this site.
The small gear on my clutch spins freely, it doesn't have any major notches in it though.
Might do the same thing you were thinking about, get my father to make one good clutch out of the two.
Thanks a lot for being so honest about it too, at least I know what I am getting.
