Author Topic: 1972 Yamaha Dt2 Mx 250  (Read 24570 times)
albrid-3
Re: 1972 Yamaha Dt2 Mx 250
« Reply #30 on: December 16, 2013, 12:00:39 pm »
You missed nothing mark, just some contents added which was about other things that wasn't related to this thread.
« Last Edit: December 16, 2013, 12:09:20 pm by Dave #6 »
« Reply #31 on: December 16, 2013, 02:43:44 pm »
That's cool Dave.
« Reply #32 on: December 16, 2013, 07:01:59 pm »
No shelpi Yamaha numbers don't work that way . All early Yamahas start with xx xx101  so the first bike off the line will be xx xx102 . Iain
« Reply #33 on: December 16, 2013, 07:11:58 pm »
When getting production numbers its best to use the model numbers the DT2MX is from memory 324 and the RT2MX 322 . this 3 digit # is model unique eg the 68 DT1 trail bike is 214 . From 74 Yamaha used these numbers in eng and frame numbers . You have most probably got fed up with my ravings so Ill sign off . Iain
« Reply #34 on: December 20, 2013, 09:54:06 am »
so RT1-09110 frame number makes it a 19..?
« Reply #35 on: December 20, 2013, 10:15:22 am »
According to my list there were two number sequences for the 1971 RT1-B (black tank/red pinstripe) 73101-75128 which I don't understand as it doesn't even follow on from the previous 1970 RT1 (black tank/yellow pinstripe) which ran from 50101--57218. The second group of listed numbers for the RT1-B are RT1-009101--024820 which would make yours the 9th RT1-B off the production line. There's a zero missing from the beginning of your number sequence but that may have been lost in translation. Can you check again? If right, you've got a very early 1971 RT1-B piston port.
« Last Edit: December 21, 2013, 12:44:18 pm by firko »
« Reply #36 on: December 20, 2013, 11:20:22 am »
According to my list there were two number sequences for the 1971 RT1-B (black tank/red pinstripe) 73101-75128 which I don't understand as it doesn't even follow on from the previous 1980 RT1 (black tank/yellow pinstripe) which ran from 50101--57218. The second group of listed numbers for the RT1-B are RT1-009101--024820 which would make yours the 9th RT1-B off the production line. There's a zero missing from the beginning of your number sequence but that may have been lost in translation. Can you check again? If right, you've got a very early 1971 RT1-B piston port.
Thanx Firko, no typo, so it is a very early 1971 RT1-B piston port, black tank red pin stripes, did check and the number given is correct,
I am still after a bottom end for it
Offline g465b
« Reply #37 on: December 20, 2013, 06:54:51 pm »
to throw a cat amongst the pidgeons            ,1971 RT1B      RT1  00901 to 24820    and
 1971 RT1B   with close ratio transmission     RT1     73101  to   75128  ,   have read about these on net and in print in my 1971 mags.
   g.
« Reply #38 on: December 20, 2013, 07:04:06 pm »
   g.
So that explains the two number sequences for the RT1-B. To be honest I've never heard of a close ratio RT1 but I guess this info tells us they exist(ed).
albrid-3
« Reply #39 on: December 20, 2013, 09:27:43 pm »
MY dt2 mx is still for sale on ebay, if anybody interested.
« Reply #40 on: December 21, 2013, 12:37:17 pm »
Sorry Dave :-[ but we are learning stuff ;)
