Author Topic: honda 1980 cr 250 forks  (Read 2465 times)
Offline LeighW
« on: November 23, 2013, 05:36:27 pm »
just picked up a 1980 cr 250 going to change the forks to 43 mm does this cause a problem at national level races  cheers leigh
Offline smed
Re: honda 1980 cr 250 forks
« Reply #1 on: November 23, 2013, 05:46:00 pm »
You can't use Honda 43mm forks going by the rules Leigh if you are racing EVO as they would be off a linkage single shock bike, The YZ465H front end is the hot legal setup,43's & TLS front brake ;),I am looking for a YZH front end for my bike at the mo :)
Offline LeighW
« Reply #2 on: November 23, 2013, 05:57:10 pm »
I thought that might be the case  got your pm just spent a small fourtune at vmx you know much about their schocks  cheers leigh
Offline smed
« Reply #3 on: November 23, 2013, 06:18:57 pm »
Yep, got a set of there  shocks on my bike,made by noleenj6 & called marty Tripes V shocks, you can buy them direct off noleen too,good value for money :)
Offline smed
« Reply #4 on: November 23, 2013, 06:38:56 pm »
