Author Topic: Marty Tripes Shocks (noleen)  (Read 12180 times)
Offline smed
Re: Marty Tripes Shocks (noleen)
« Reply #15 on: June 23, 2013, 07:45:40 pm »
Update,I finally got to use these shocks & am extremely happy with them,Clark seems to have them dialled in spot on for me,they have no clickers only preload adjustment,I have them set with about 70mm sag which matches the sag on my forks,the bike seems well balanced & confidence inspiring to ride 8).
I have had one small problem with the lower eyelets moving sideways on the rubber bushings & riding on the steel spacer built into the swingarm,To fix the problem i slipped a sleeve  over the spacer as you can see in the pic,but now am thinking i need a large washer with the same OD as the eyelet as well to be 100%,this is probably not an issue on most bikes as the eyelet sits in a tight u shaped bracket ;)
