Author Topic: Australian made bike  (Read 10833 times)
Offline brent j
Re: Australian made bike
« Reply #15 on: December 01, 2013, 08:09:04 pm »
Things moving along nicely  ;)
360cc disc valve
Any details yet Lozza? Not being a smart arse but but why 360cc? is it a Class limit? is it an ideal bore/stroke ratio? there must be a reason for the size. Does it run a power valve. You've got me intrigued.
I think about my TS90MX with the rotary valve motor, even with 15-16hp it was still very flexible and would potter along happily just above idle. For a 90cc motor it was remarkably flexible. And that was before they thought of power valves.
« Reply #16 on: December 01, 2013, 10:09:52 pm »
I dunno Brent, that's just what the bloke(who is making the engine) wanted, meant to compete with 450F's. Think its about 77 X 77mm, can have a PV but probably won't need that as variable disc timing is planned. Correct Brent disc valves are superior  ;)
Offline brent j
« Reply #17 on: December 01, 2013, 10:49:22 pm »
Variable disc timing, that sounds interesting. I've read the power valves knock pistons and rings around, if it's right then that's a bonus plus the disc valve set up gives a lot more room for more transfer ports. The Ts90MX has more transfer area than the TM125
« Reply #18 on: December 02, 2013, 08:30:42 am »
Would that be the same system as he showed in the Kiwirider article? Some interesting ideas from the looks of it
« Reply #19 on: December 02, 2013, 09:23:32 am »
Yep that's it Tony
Offline Mike52
  • 81 KTM 125 LC
« Reply #20 on: December 03, 2013, 09:35:59 am »
If someone wanted to make a bike here in Australia then maybe a Adventure Bike would be the way to go.
A simple little thing that the owner could work on out in the Simpson.
A bike with NO
Watercooling
ABS /ABN /traction control ???
Actually no tricky electronics would be the go.
A bike that uses rider input to do the job. ;D
A bike where you could get the bad fuel out in a couple of minutes instead of hours.
Fit a single cable slide carb instead of a vacuum controlled thing.
A bike where you could change the headlight bulb in 5 mins instead of 1 hr.
If you left all the tricky bullshit off it I'll bet you could make it cheap as well as reliable.
Mike
« Reply #21 on: December 03, 2013, 09:47:00 am »
A bike with NO
Watercooling
Mike
Can you make it cheaper and more reliable and with better spares support than an XR400/600?
If not, why would anyone buy the new Aussie made bike over an old XR?
Offline Husky500evo
« Reply #22 on: December 03, 2013, 12:58:04 pm »
Hasn't Paul Rooney been making bikes like this for years ? Although not totally Australian made, as he uses BMW motors, WP forks and usually Ohlins rear suspension. But he makes his own lightweight frames and sells completed adventure bikes to people all over the world. Just a one man operation, where he builds the bikes in a workshop under his house.
http://rooneycycle.wordpress.com/cycles/
« Last Edit: December 03, 2013, 01:07:07 pm by Husky500evo »
Offline Mike52
  • 81 KTM 125 LC
« Reply #23 on: December 03, 2013, 05:40:47 pm »
And there you go.
Nothing more to say really.
« Reply #24 on: December 03, 2013, 06:21:35 pm »
Very interesting!
Offline mustanggrahame
« Reply #25 on: December 03, 2013, 07:17:02 pm »
NO motorbike should be made with an engine that rotates at right angles to the wheels.
