Author Topic: BSA project  (Read 25852 times)
BSA project
« on: November 03, 2013, 09:20:16 pm »
Unfortunately I've decided I'm just not going to get this one done due to other stuff that's going on. I thought I'd offer it here as a package before I split it up on ebay. I've paid more for the parts than I'm asking.
BSA B40WD engine, seems to have good compression was apparently "rebuilt". I was always intending to pull it down and go through it though. The gearing on these would need to be changed for mx anyway. The stock WD gearing is more suited to trials. Comes with carb and header pipe.
BSA B40WD frame and swingarm. Very good condition, I've had inserts machined to fit the Betor triples included. Comes with a new set of swingarm bushes.
Betor 35mm forks and triples. Excellent condition, just need seals.
Rickman front hub, brake plate and axle.
Early Yam full width hub, brake plate, and axle
New spokes to suit Yam front hub, used spokes to suit Rickman front hub
CZ rear hub, brake plate, axle and adjusters
Used 36 hole Mudcatcher rear rim, needs polishing
Used 36 hole Mudcatcher front rim, still laced up to TM400 front wheel, needs polishing
New vintage style Magura trapdoor throttle and slimline grips
2 x sets of Tomaselli style levers
Used alloy front and rear guards
American Eagle tank, needs sealing, resto etc.
$1300
pic of frame with eagle tank
older pic with BSA tank which has since been sold
Montynut
Re: BSA project
« Reply #1 on: November 03, 2013, 09:29:36 pm »
without showing my ignorance is this Pre65 or Pre70?
Oops I just showed my ignorance ???
TM BILL
Re: BSA project
« Reply #2 on: November 04, 2013, 05:54:56 am »
Finish it Paul, you have spent a fair bit of time gathering those parts and are a fair way there :)
I am the master of unfinished projects  ::) and i have moved a few on unfinished and regretted it .
You will be well happy when you have completed it and will enjoy the class  :)
Come on you know you can do it  :)
Offline big mac
Re: BSA project
« Reply #3 on: November 04, 2013, 06:57:33 am »
Where is the bike situated please. thanks Rory
Offline flower pot racing
Re: BSA project
« Reply #4 on: November 04, 2013, 07:20:59 am »
Might want to double check that B40 motor....
It looks like it could be a CCM unit as it appears to have the pineapple top end on it.  Very Trick!
Offline bazza
Re: BSA project
« Reply #5 on: November 04, 2013, 07:25:18 am »
hope you change your mind and finish the build
Embrace patina
Simo63
Re: BSA project
« Reply #6 on: November 04, 2013, 07:50:57 am »
Pm sent Paul
Re: BSA project
« Reply #7 on: November 04, 2013, 08:27:12 am »
Paul ... hang in there bud, you will get there in the end.
Refer to TM bills Post .
Offline YZ250H
  • Back in QLD Baby !
Re: BSA project
« Reply #8 on: November 04, 2013, 08:34:21 am »
Finish it off (or put it back under the bench).  It's not like you've got anything else to do.  ::)
Re: BSA project
« Reply #9 on: November 04, 2013, 10:42:44 am »
Thanks for the words of encouragement, I didn't make the decision lightly. Looks like it might be moving on to someone who I know will finish it and from what I've seen in the past will do a beautiful job.
Offline YZ250H
Re: BSA project
« Reply #10 on: November 04, 2013, 10:58:54 am »
Fair enough.  If you get lonely and need a project to work on I can always bring one of mine over  ;D ;D
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: BSA project
« Reply #11 on: November 04, 2013, 11:04:45 am »
Umm... Tony o'le mate...
any chance i could get that offer too with say...
maybe a...
TY250...?
"flat bickie"
Offline YZ250H
Re: BSA project
« Reply #12 on: November 04, 2013, 11:48:43 am »
No worries Mick, except I would never get the bike back  ;D
Montynut
Re: BSA project
« Reply #13 on: November 04, 2013, 07:49:29 pm »
PM sent
Re: BSA project
« Reply #14 on: November 04, 2013, 08:56:36 pm »
Thanks for all the interest, the bike has been sold.  Should be a good thing when it's done. Cheers
