Author Topic: Shock length  (Read 2990 times)
Offline scottm
Shock length
« on: October 23, 2013, 05:37:15 pm »
Can anyone suggest a replacement for rear shocks on a 1979 wr 390 husky, and what length eye to eye
cheers Scott
pre 84 thank you very much
Offline HVA61
Re: Shock length
« Reply #1 on: October 23, 2013, 06:22:47 pm »
420mm eye to eye with remote res.
Ebay usa is a good source
if you get stuck i have a few sets
Offline scottm
Re: Shock length
« Reply #2 on: October 23, 2013, 08:21:17 pm »
Thanks Rob
Offline Husky500evo
Re: Shock length
« Reply #3 on: October 27, 2013, 05:47:18 pm »
     Hey Shoey, are you sure about that ? I used a set of 383mm Ohlins remote reservoirs off a '79 390 Auto (which would be the same as a WR) on my '77 CR390. I could be wrong, so I might have to go and double check, but I thought that the '79 CR250 and 390 had 420mm remote reservoir shocks, but the WRs had shorter 383mm shocks. The WR and CR125 models always seemed to lag a year behind the bigger CR models, with technology and the '78 CRs were the first ones to come out with Ohlins (383mm)   I have a '79 CR390 buried in my shed somewhere and I have the shocks off it, with a tag on them telling me what they are from. Might have to go and run a tape measure over them.
      But as you say, Ebay USA is definitely the best source.
« Last Edit: October 28, 2013, 07:14:45 am by Husky500evo »
