Author Topic: what is this?  (Read 6361 times)
Offline hitatreeonce
  • rather be an old fart than a young dickhead
what is this?
« on: September 29, 2013, 09:08:54 am »
anyone what this is looks like it was once watercooled the pump has been pluged up has a hydrolic clutch no on frame is 3650488 cant find one on the motor any help appreciated
Offline paul
Re: what is this?
« Reply #1 on: September 29, 2013, 09:41:50 am »
85 frame I think .the photo is bad ,you sure there no engine number
Re: what is this?
« Reply #2 on: September 29, 2013, 10:08:56 am »
There is a number on the barrel but it doesn't fit properly some of the fins would have to be trimed to clear the down tube I cant find any numbers on the cases
Offline Maicoman
Re: what is this?
« Reply #3 on: September 29, 2013, 02:21:20 pm »
Looks like an 85 frame, but it has rear shock mounts :o and perhaps an 85 250 motor that someone has tried to fit a 490 barrel to or someone has just fitted a watercooled clutch cover to a 490 motor.
 Do all the lower frame mounts match up because 84 & 85 are different?. There is an extra lower mount. Looks like a custom airbox, perhaps a works bike or just a bitsa?
Re: what is this?
« Reply #4 on: September 29, 2013, 06:39:18 pm »
All the mounts line up Doubt its a works bike but if the rear has been retro fitted its a good job
Re: what is this?
« Reply #5 on: September 29, 2013, 06:48:15 pm »
I'd say the subframe has been grafted to another frame to suit dutch twin shock and the same with 83/85 500 cylinder. The main frame doesn't look like any Maico frame I've seen, although I've never seen a naked waterpumper 500, saying that I can't see any rad mount points.
The U.S did have 1985 air cooled 500's.
Re: what is this?
« Reply #6 on: September 29, 2013, 11:07:02 pm »
The 365 frame number comes up as a 1985 gm 250
http://www.maicoonly.co.uk/engine-and-frame-numbers.html
Re: what is this?
« Reply #7 on: September 30, 2013, 07:32:11 am »
Thanks fellas from what I can figure out its a retro fitted twin shock liquid cooled 250 with a 490 barrel grafted on
Re: what is this?
« Reply #8 on: September 30, 2013, 09:40:43 am »
Life's like a box of choclates......you never know what you're gunna get... :)
Offline 09.0
Re: what is this?
« Reply #9 on: October 01, 2013, 07:42:19 pm »
The air cooled barrel from the later bottom end bolts on. Is this a bike you have stumbled onto? I have just bought a similar bike in bits. Is it a blue bike (plastics).
