Author Topic: AW 400 clutch questions. Help needed!!  (Read 4025 times)
Offline silverfox
« on: September 20, 2013, 10:04:43 pm »
Just about to assble the clutch on my 77 AW 400, do the cup washers go in packs of 2 or packs of 4? eg. 10 x 2 or 5 x 4? That make sense?? also, do I run 7 steel plates or 6? If 7 where does it go?? first time putting a Maico engine together!! Thanks
To many, 72 Husky CR400, 73 Husky CR250, 77 RM370 x 2, 77 & 79 Honda CR125, 77 AW400, 82 CR480, 87 430 auto, 79 Honda 500/ Husky hybird
Re: AW 400 clutch questions. Help needed!!
« Reply #1 on: September 20, 2013, 10:47:50 pm »
The cupped washers go in 5 packs of 4 like this  (( ))
You can run the extra steel in the middle of the pack with another steel, it preloads the plates more for less chance of the clutch slipping.
Wouldn't hurt to get a workshop manual..
Offline silverfox
« Reply #2 on: September 21, 2013, 08:20:19 pm »
Cheers mate, all sorted. Got it all together, and now the kickstart won't return. FFS, I will have to pull it apart again and put another turn on the spring, Guessing that is what as needed as I put it in with little tension on it and it won't ratchet back
Offline Maicojames
« Reply #3 on: September 29, 2013, 03:27:57 am »
If it happens again with engine in chassis, it may be "tip to tip". Meaning the kick gear meshed with primary gear and jammed.  Put trans in 3rd and rock, frees it up
Life is suddenly very Monaro
