Author Topic: Kawasaki KS/KE125 Pre75 ELSINORE MUNCHER  (Read 14281 times)
« on: September 16, 2013, 07:17:36 pm »
I just bought one of these, but don't know the age of it?
It is the first early style of rotary induction engine.
« Last Edit: September 18, 2013, 08:12:25 pm by Mick D »
Re: Kawasaki KE125 Any Good ? Pre75 or Pre78 ?
« Reply #1 on: September 16, 2013, 07:25:40 pm »
Offline oldyzman
  • 250 two stroke!
« Reply #2 on: September 16, 2013, 07:29:53 pm »
I see a dirt tracker, cute bike but does it have the power?
Brett
« Reply #3 on: September 16, 2013, 07:53:44 pm »
Brett
Gooday Brett, that sounds like a very good idea, since it was so dirt cheap 8)
I couldn't help myself, just scored three days work in the big smoke with a half empty work truck :)
so I did a quick search, and what do ya know, only bidder :)
My first experience of the two stroke rush;
  didn't happen on my mates Bantam :-\
It happened on my other mates Rotary Induction Kawasaki 120, "Bush Ranger" I think it was called?
Damm thing flew, like a Stabbed Rat as Mike52 would say :D :D :D :D
« Reply #4 on: September 16, 2013, 08:09:56 pm »
Bugger was looking for a sub 200cc bike to register. Looks KH125 based, so that can be made to put out some serious HP. In standard form you will be limited by a shit ignition, ditch that and worlds your oyster. Don't be afraid of switching pistons on them as standard KHI and aftermarket replacements will do this when everything else is sorted. For mx the frame geometery doesn't look the best, but who cares when you can out drag everyone. ;)
Offline Rodpack
« Reply #5 on: September 17, 2013, 12:48:03 pm »
Lozza, I got a 1980 KE125 that'll go OK with a bit of work and has all the road legal stuff on it. And it's in Mayfield too! If you're interested let me know.
Re: Kawasaki KS125 Pre75 ELSINORE MUNCHER
« Reply #6 on: September 17, 2013, 06:20:15 pm »
How good is that Lozza. Let me know if you don't want it ;D
Mine was picked up today. Apparently its a KS125 ?? build date on plate 4/74
it is so cool to have a little win for a change :)
I had three of those little elsies when I was a juvenile
but they are getting to expensive for me to buy now.
Anyhow as you say, on paper this little KS girl with it's six speed box and rotary disk induction
 should eat the elsies up for breakfast in a drag race :) He He he 8)
« Last Edit: September 17, 2013, 06:39:19 pm by Mick D »
« Reply #7 on: September 17, 2013, 06:45:53 pm »
Here is a 74 KS125 tank for sale on US ebay
http://www.ebay.com/itm/1974-KS-125-Kawasaki-Fuel-Tank-Petcock-Cap-and-Rubber-Mounts-/300965164120?pt=Motorcycles_Parts_Accessories&hash=item4612ebf458&vxp=mtr
Similar graphics as mine, just a different colour.
From what I can find so far, this style of graphics seems only to be for 74? I am thinking?
I am liking the look of the Green Machine theme heaps more than Mellow Yellow, that's for sure
« Last Edit: September 17, 2013, 06:53:22 pm by Mick D »
« Reply #8 on: September 17, 2013, 08:27:45 pm »
Found a thread in the Aussie Vinduro Forum
http://www.vinduro.com.au/forum/index.php?topic=1161.0
Offline farmer58za
« Reply #9 on: September 17, 2013, 08:32:35 pm »
1974 KS125 - that's right "in the zone"
I'm not sure what the gear ratios are but it's likely that a KX top end and rotary valve will bolt right on. Failing that, a good port job, cut valve and larger carb will get it cooking.
KS 125 forks share some common parts with the KX. Generally, parts are readily available. Some parts are still available from Kawasaki.
I have a "Dirt Bike" article on making the KX better....
Regards
David
Dave's not here man
« Reply #10 on: September 17, 2013, 08:45:53 pm »
32 degrees :D ;D made my nite!!!The shit that add men thought were important!
Offline Doc
« Reply #11 on: September 17, 2013, 09:28:17 pm »
I had (still have) the street version..on the long list of to do :P it did go exceptionally well :)
« Reply #12 on: September 17, 2013, 09:50:14 pm »
Oddly when I read that John, I thought, they obviously didn't see the run ups we used to get first as kids ;D
Thanks for the tips David. I checked Ebay US and your right there is tons of stuff, including NOS, but might check the dealer first now.
http://www.ebay.com/sch/i.html?_odkw=kawasaki+ks125+frame&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.XKawasaki+KS125+&_nkw=Kawasaki+KS125+&_sacat=0
That is one beautiful looking machine Doc, I hope you didn't drop it or stack it :'(
You posted it once before, I thought it had a different seat on it then?
It was staring at it that got me started down this path Doc. I have collected an early KH100 bottom end and a  set of 125 internals. I bought this bike for spares actually. But now I have found it to be a 74,,,,,,,,,,,,,,,well as you can imagine, it is a pleasant surprise that changes my previous intentions   :)
Offline g465b
« Reply #13 on: September 17, 2013, 10:14:57 pm »
hi, a dyno chart in an old mag for the 74 KS125 states 4.8hp@4000rpm   6.9@5000    9.8@6000 and peaks at 10.4@7500.
kawasaki, claimed 13@6500 ,may need some teeth to do some munching.    cheers g.
« Reply #14 on: September 17, 2013, 10:24:35 pm »
I have been waiting for it ;D
Yeap, be fitting some teeth first 8)
