Author Topic: Kawasaki KS/KE125 Pre75 ELSINORE MUNCHER  (Read 14282 times)
Re: Kawasaki KS125 Pre75 ELSINORE MUNCHER
« Reply #15 on: September 17, 2013, 10:47:13 pm »
hi, a dyno chart in an old mag for the 74 KS125 states 4.8hp@4000rpm   6.9@5000    9.8@6000 and peaks at 10.4@7500.
kawasaki, claimed 13@6500 ,may need some teeth to do some munching.    cheers g.
That's disc valve clydesdales not limp wristed cravat wearing reed valve/piston port shetland ponies  ;)
That was sort of what I had in mind Doc.
Offline Doc
« Reply #16 on: September 18, 2013, 07:46:42 am »
Mick..I still have kermit and it is still straight and complete but exhibiting much 'patina' from many years of sitting neglected.
Offline JC
« Reply #17 on: September 18, 2013, 12:19:59 pm »
Mick I think you'll find the KH100 bottom end is no use to you. The 100 & 125 Kaw engines are completely different.
I think I still have a spare KX125 cylinder in the shed if yr interested.
« Reply #18 on: September 18, 2013, 12:44:58 pm »
Thanks for the heads up JC. I wish I knew that last night ;D
After what David said I bought a new KX head from Vic and a used KX Cylinder from US.
I will post pics and links tonight after work.
Still very interested though,,,did you have a figure in mind? PM possibly JC.
Cheers :)
PS got a smick 32mm Ceriani front end of a 175 74 Penton :)
