Author Topic: wanted front brakes to suit a 89 model cr 250  (Read 3801 times)
Offline darren
« on: August 29, 2013, 08:20:23 am »
front brakes wanted to suit an 89 model c 250
i have a set from a 88 model to trade or sell
Re: wanted front brakes to suit a 89 model cr 250
« Reply #1 on: August 29, 2013, 09:22:54 am »
I forgot to reply to your email...  :-[
Someone else can probably confirm, but I'm pretty sure the front caliper is the same until 1993, at least.
Offline darren
« Reply #2 on: August 29, 2013, 01:22:08 pm »
the clymer manual also says the 88 and 89 are different,,the 88 one i have doesnt line up with the mounts on the forks,,,not sure thou if they use another bracket or they bolt directly to the forks
Simo63
« Reply #3 on: August 29, 2013, 01:28:00 pm »
Whitey 43 recently purchased a couple of 88 or 89 models and might be able to help.  Send him a PM as he is a very helpful guy.
« Last Edit: August 29, 2013, 01:37:32 pm by Simo63 »
Offline darren
« Reply #4 on: August 29, 2013, 01:55:21 pm »
not sure how to contact him,,whats the trick
Simo63
« Reply #5 on: August 29, 2013, 01:57:46 pm »
Go to my messages, send a message (all above ^^^^^) and type in whitey 43.  His user name should come up and you can send a message.
Offline whitey 43
« Reply #6 on: August 29, 2013, 02:26:42 pm »
Cheers Simmo  ;D
« Reply #7 on: August 29, 2013, 03:13:13 pm »
Yep. The mounting points on the RWU Honda disc fronts was the same from 83-89 (and maybe for the later XRs?).
They changed to the mounting points with the bolts much closer together for the first USDs in 89. Don't know how long that kept going for.
Offline Cooch 04
« Reply #8 on: August 29, 2013, 03:28:15 pm »
PM sent
Offline Cooch 04
« Reply #9 on: August 29, 2013, 03:29:17 pm »
Sorry email sent ;D ;D ;D
Offline whitey 43
« Reply #10 on: August 29, 2013, 03:33:09 pm »
89-91 is the same carrier (Bracket) I think they changed after that...
Offline Cooch 04
« Reply #11 on: August 30, 2013, 01:37:13 pm »
Am interested in buying 88 front brake setup,is it in good working condition is it master cylinder and calliper and how much do you want for it ???
« Reply #12 on: August 30, 2013, 03:54:00 pm »
I have a 94 set if thats some help . dosent look hard to retro fit
