Author Topic: M180  (Read 2268 times)
Offline BULTACOBRIS
M180
« on: August 13, 2013, 07:41:59 am »
Finally fired it up, albeit with an Alpina motor. Really the ideal combo for trail ridin, but the fresh Alpina is way too lean on std jetting with that Circle F pipe, and i don't have the time to sort it. Plus it is required elswhere.
Have just started to rebuild the Frontera motor. The Bore has a small approx 2mm x 1mm deep nick, not sure on the repair options, any suggestions? (it is +2 now)
Also, the primary chain tensioner is missing. I was told that this is ok on Fronteras and Pursangs?
« Last Edit: August 13, 2013, 07:47:06 am by BULTACOBRIS »
Offline Matador107
Re: M180
« Reply #1 on: August 13, 2013, 08:38:54 am »
There is someone in Midwest USA who can resleeve  a cylinder. One of the US guys may know, I know of someone who sent his over from Oz to get it done.Will try to get his email for you.
Apart from that, try SERCO in Brisbane.
Bultaco Metralla, Matador MK 5, Montadero mk2, El Bandido model 18,plus lots of bits and two Honda XR's 250,350.
