Author Topic: Hubs. Paint or powder coat??  (Read 4557 times)
Offline Paul552
  • HEAVEN #552
« on: August 10, 2013, 05:05:45 pm »
Like the question says paint or powder coat on hubs?
Whats best??
Thinking powder coat would be a pain around the spoke holes??
Interested in opinions on what's best?
Offline mick25
  • Hunter valley NSW
Re: Hubs. Paint or powder coat??
« Reply #1 on: August 10, 2013, 05:29:19 pm »
Paint for me ( satin black ) ;)
I am not keen on powder coats , bitch to remove later and to thick for my likes.
I have herd it can crack on frames ( flex ) and water can get in there and rust the frame
Offline Paul552
  • HEAVEN #552
« Reply #2 on: August 10, 2013, 05:47:43 pm »
Thanks Mick
I was thinking that way
Thanks for the feedback
Simo63
« Reply #3 on: August 16, 2013, 03:21:48 pm »
Personally I hate powder coating metal as that can create all sorts of problems with corrosion so I would never do it to a frame or such but I can't see a problem (aside from spoke hole clearance) with powdercoating alloy hubs.
Offline Paul552
  • HEAVEN #552
« Reply #4 on: August 16, 2013, 04:21:38 pm »
Thanks for the feed back
I'm going to go for paint.
I was thinking about trying engine enamel as it is pretty tough an hard wearing.
Offline Viper79
« Reply #5 on: August 16, 2013, 05:13:24 pm »
I use PPG, GMH sub frame satin black.  If you have a spray gun that is..
It's been on the hubs of my RM400 for twelve years and still looks new.
I have used it on all of my resto's.
You need to give it light coats and leave it to dry overnight between coats.
QA50 KO, XR75 K5 Race bike from VMBA days, XR400R1, CRF450R3, RM400T, DR650SE with off road adventure mods, MX360A, YZ400D, YZ465H, IT250H, 1985 Jawa 897 Slider, 2016 Jawa/GM Slider
Offline bishboy
  • Toowoomba
« Reply #6 on: August 16, 2013, 05:22:51 pm »
It's probably a combination of what look you want, whether it's a racer or a garage queen and if you can paint it yourself (even with spray cans)
I'm going to probably do my couple of restos with spray cans, unless I buy myself a compressor, but I will also leave some items unpainted after vapour blasting for that worksy look  ;)  The bikes are only going to be racers and you can get a good result doing it yourself with patience and preparation.
Offline Paul552
  • HEAVEN #552
« Reply #7 on: August 16, 2013, 05:39:11 pm »
I have a paint gun and reg so I will give your recommendation a go.
Thanks for the tip
Offline Viper79
« Reply #8 on: August 16, 2013, 06:50:21 pm »
You can see some photo's on here, the hubs on the 400D will give you an idea of the finish.
http://www.ozvmx.com/profile/RobertCain
Offline Paul552
  • HEAVEN #552
« Reply #9 on: August 16, 2013, 07:58:25 pm »
Thanks again for the tip Rob and I goto say man that is on nice 400D! :)
« Reply #10 on: August 18, 2013, 09:54:13 pm »
I used a spray can etch primer that did a great job on my cases (satin black)
