Author Topic: Info on new CR480 rod kit  (Read 8766 times)
Offline mick25
  • Hunter valley NSW
« on: July 15, 2013, 06:00:33 pm »
A mate of mine is chasing a new rod kit for a 83 CR480 , any info where to get one will be tops.
I don't know if the 82 CR480 is the same or even the 84 CR500.
someone with a Honda zedder disc may know.
Thanks mick
Re: Info on new CR480 rod kit
« Reply #1 on: July 15, 2013, 09:40:13 pm »
Me thinks 82 and 83 same...NLA, 84 500 available but longer, by about 12mm I think.
I have been down the road of fitting a 84 rod to an 82 with spacer under bottom of cylinder, only to find exhaust port was raised to high and was half blocked off by frame main front down tube. I should have taken $750 out into the back yard and burnt it, would have saved me two months of flucking as I ended up reusing the old rod....
« Reply #2 on: July 15, 2013, 11:20:21 pm »
Could have found a piston with a lower comp height  ;)
« Reply #3 on: July 16, 2013, 09:45:26 am »
Would there not be something that is closer than 12mm longer out there?
Part # = 13201-KA5-770
Part Description = ROD, CONNECTING
Model Count = 2
CR480R-C 1982 480 CR480R Off Road
CR480R-D 1983 480 CR480R Off Road
« Reply #4 on: July 17, 2013, 01:53:44 pm »
....now ya bloody tell me...
Offline mick25
  • Hunter valley NSW
« Reply #5 on: July 17, 2013, 08:41:43 pm »
Thanks for the info so far guys ;) hes trying a bloke in the uk for one fingers crossed.
Offline Matador107
« Reply #6 on: July 17, 2013, 09:14:32 pm »
Have a look at this bloke in the UK. He is an agent for Italkit and I know he will sell to Aust because I enquiried some time ago. Kevin Breedon Racing.
Martin
Bultaco Metralla, Matador MK 5, Montadero mk2, El Bandido model 18,plus lots of bits and two Honda XR's 250,350.
Offline Matador107
« Reply #7 on: July 17, 2013, 09:51:08 pm »
This bloke as well apparently he manufactures. Phil Denton Engineering in England.Hope it all helps.
« Reply #8 on: July 18, 2013, 12:22:16 pm »
You never asked ;D
Montynut
« Reply #9 on: July 18, 2013, 02:53:12 pm »
Martin
Kevin is great good guy and will go out of his way to help as he is a vintage racer himself. He has raced CRR & VMX on Bultaco for many years. He has contacts with Italkit and has obtained parts from them in a few days for me in the past. Highly recommended.
Offline mick25
  • Hunter valley NSW
« Reply #10 on: July 18, 2013, 07:07:12 pm »
Thanks for the heads up  ;) the bloke hes trying in the uk is phil denton as you said ;)
Thanks for the info lead montynut will let him know :)
Offline crabman
« Reply #11 on: July 18, 2013, 07:18:08 pm »
Thanks mick
You can get a new CR 480 rod kit from Phil Denton Engineering in the United Kingdom
web address www.phildentonengineering.com
Old and slow - and happy
« Reply #12 on: July 18, 2013, 07:23:48 pm »
Another place to try would be trimac in Auckland, they've been making billet rods for various bikes for a while. Their work has been pointed out on here a few times, pretty sure they've sold both on trademe & ebay
Have a look at the video in about us, a billet Norton commando crankcase  :o
http://trimacmachining.com/index.html
