Author Topic: 79 KX250/KLX250 questions  (Read 8679 times)
Offline bishboy
  • Toowoomba
« on: July 03, 2013, 09:48:32 am »
Couple of questions about fitting other parts to a 79 KX250/KLX250
-  Would a seat off a 79 KLX250 fit on a 79 KX250?  I'd have to think it would go close given the KLX frame is a KX125 frame?
-  Would a YZ 43mm front end increase the front end travel and ride height and would the rear end need to be adjusted to compensate?
     -  same question but for a 79 KLX250 frame?
TM BILL
Re: 79 KX250/KLX250 questions
« Reply #1 on: July 03, 2013, 09:55:48 am »
Yes seat will fit  :) I don't know where this a KLX 250 is the same as a KX 125 frame comes from though  ??? I hear it all the time , there similar but they sure aint the same  ;)
Offline bishboy
  • Toowoomba
« Reply #2 on: July 03, 2013, 11:37:11 am »
I understood that the klx frame was the 125 frame with a kink in the top tube to clear the four stroke head?
« Reply #3 on: July 03, 2013, 12:11:07 pm »
LOL The same frame myth might have been originally used by salesmen. I have never put them side by side but knowing the japs Im sure there is little or nothing except frame colour
TM BILL
« Reply #4 on: July 03, 2013, 12:34:17 pm »
Geometry might be similar ( im not clever enough to measure that  ;D ) but they are different in many ways . I put them side by side this morning after my last post  :)
Offline bishboy
  • Toowoomba
« Reply #5 on: July 03, 2013, 02:46:21 pm »
Well there you go, you learn something everyday  ;)
What about putting the YZ front end on the KLX or KX, any changes to rear end needed?
TM BILL
« Reply #6 on: July 03, 2013, 03:45:25 pm »
Cant answer that , but im thinking of ditching the Fox forks in my 250 A5 for a Yamaha 43mm front end so will find out I guess  ;D
Offline Maicoman
« Reply #7 on: July 03, 2013, 06:02:12 pm »
This is what was reported by ADB at the time of testing back in 79/80. They stated it was a modified kx 125 A5 frame. There are a lot of similarities between Kawasaki models. The KX 125 A6 and KDX 175 share alot of parts. It helps when looking for spares.
   I had a similar query recently looking for a seat for my KX 250B1. A KDX seat is nearly the same but is about an inch shorter at the rear. That's why when you see 83 model KX's with a big gap behind the seat, you'll find it's likely to be a KDX seat.
Offline oldcol
« Reply #8 on: July 03, 2013, 07:51:36 pm »
Anybody know the easiest way to fit 38mm forks in a 79 KX125, what tripleclamps to use or do I press the stem out and fit to other clamps, Thanks Col.
TM BILL
« Reply #9 on: July 03, 2013, 07:57:34 pm »
Fit a complete 79 KX 250 front end  :)
Offline oldcol
« Reply #10 on: July 03, 2013, 09:06:51 pm »
Thanks Bill, I was planning on using Yamaha forks I have in shed. Anyone have a set of 79 KX250 tripleclamps for sale, Thanks Col.
Offline geraldo
« Reply #11 on: July 04, 2013, 06:43:05 pm »
the KLX250 prototype was created by a small team at Kawasaki USA by shoehorning a KL250 motor into a KX125a4 chassis , once the factory Ok'd the project they built a frame based on the prototype & used the swingarm out of the KDX400 twinshocker & the KLX was born
Offline geraldo
« Reply #12 on: July 04, 2013, 06:51:29 pm »
here is a picture of the original prototype
