Author Topic: rm125 / pe175  (Read 8198 times)
simon414
rm125 / pe175
« on: June 22, 2013, 07:49:19 pm »
Hi
Just a quick question would a PE175 barrel fit a RM 125 of the same year??
Re: rm125 / pe175
« Reply #1 on: June 23, 2013, 10:09:47 am »
The short answer is no.
Offline oldyzman
  • 250 two stroke!
Re: rm125 / pe175
« Reply #2 on: June 23, 2013, 11:28:59 am »
Will an RM125A cylinder fit onto a RM125B bottom end? or vice versa...
Brett
TM BILL
Re: rm125 / pe175
« Reply #3 on: June 23, 2013, 12:04:42 pm »
Brett
Physically yes but the stroke is different so you have to change cranks to .
TM BILL
Re: rm125 / pe175
« Reply #4 on: June 23, 2013, 12:16:49 pm »
Hi
I don't know about the later models 1980 on but the earlier ones don't fit no.
Offline Tomas
Re: rm125 / pe175
« Reply #5 on: June 23, 2013, 02:23:13 pm »
PE motor in RM frame looks much easier to do.  http://www.acrmx.com/forum/topic.asp?TOPIC_ID=1196
Offline Dono113
Re: rm125 / pe175
« Reply #6 on: June 23, 2013, 04:26:49 pm »
Hi
Looks like someone is chasing an edge ;D
1983 CR125R
2003 CRF450R
CB750K1
2005 YZ85
1969 TS 250
Offline oldyzman
  • 250 two stroke!
Re: rm125 / pe175
« Reply #7 on: June 23, 2013, 04:28:39 pm »
Nifty had a rm125A with a PE motor fro his missus to run DT at nepean...
Re: rm125 / pe175
« Reply #8 on: June 23, 2013, 05:17:44 pm »
Hi
The 175 is a nice motor.  I race mine in the evo 250 class, lots of fun and no real scare factor if you're a gumby ;D
Re: rm125 / pe175
« Reply #9 on: June 23, 2013, 05:49:06 pm »
Been there done that (PE175 in RM chassis). Nice bike for playing but a standard RM125 is a better race bike. Same goes for KDX175 into KX.
« Last Edit: June 23, 2013, 05:51:10 pm by bigk »
Re: rm125 / pe175
« Reply #10 on: June 23, 2013, 06:18:58 pm »
Yeah, but using the bigger motor means you're up in the 250 class. So if you're looking for a 250 class ride rather than a 125, the 175 is a good option if you can't use all the power a 250 puts out.
Re: rm125 / pe175
« Reply #11 on: June 23, 2013, 06:54:05 pm »
I'm with you Paul....I have a KX125 A5 roller that I'm gonna build a VMX Mag Ken replica like in the current mag....awesome play bike.
Offline Dono113
Re: rm125 / pe175
« Reply #12 on: June 23, 2013, 08:20:30 pm »
Nifty stills has the "PERM" tucked away ;)
1983 CR125R
2003 CRF450R
CB750K1
2005 YZ85
1969 TS 250
simon414
Re: rm125 / pe175
« Reply #13 on: June 23, 2013, 08:48:08 pm »
Thought it would be a quick question lol
Re: rm125 / pe175
« Reply #14 on: June 23, 2013, 09:16:11 pm »
Yep, should have suck with the short answer, but went the long way to end up with a slim PE175 rather than a big bore RM125.
