Author Topic: Wanted 1979/80 CR125RZ/RA/RB Transmission washer 90457-700-305  (Read 1159 times)
Offline SteveG47
Hi Guys,
Can anyone help, I'm looking for a 15mm Thrust Washer Part No. 90457-700-305.  it sits on the l/hand side of the countershaft on a CR125 RZ /RA / RB, (spigot end, opposite end to the front sprocket)
Or, if anyone has a decent Countershaft off a 1979/1980 CR125RZ or CR125RA with this washer on it I would consider that too.
Steve.
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
Re: Wanted 1979/80 CR125RZ/RA/RB Transmission washer 90457-700-305
« Reply #1 on: May 02, 2013, 08:24:41 pm »
Tippin you're a Honda man Steve, feel free to tell us a little about yourself and you're bike passion when you've got a chance. Have you already checked all the usual parts websites for what you're after?
Offline SteveG47
« Reply #2 on: May 03, 2013, 11:42:37 am »
Yes Rookie, I have always been mainly hooked on the red ones, Off and On Road!
Currently have a CR125RY just for a bit of fun with my youngest, but I'm also rebuilding an RA motor (slowly).
I am on the look out for an old RZ/RA basket case to play with.. the RH chain driven Elsinores are of the era I grew up in  :)
I've googled websites, Ebay, David Silver in the UK etc, sounds like this washer was made obselete by Honda a long time ago, even the complete shafts I see on Ebay in the States do not seem to have them fitted (I think it must stick on the inside of the LH case on disassembly and gets lost/mislaid).
Even if I can get the thickness of one I could then make one up - it is just a plain hardened thrust washer..
Steve.
