Author Topic: CR125RZ, is it possible to fit new crank shaft seals without splitting the case  (Read 1641 times)
Offline oldyzman
  • 250 two stroke!
Seeing the bottom end is good on the bike i am resto'ing can the crank seals be replaced without splitting the cases as i would think the seals should be replaced.
I have looked at some info but cannot tell?
Cheers Brett
Offline smed
I would think you should be able to :)
