Marque Remarks
Honda
CR125RZ, is it possible to fit new crank shaft seals without splitting the case
Topic: CR125RZ, is it possible to fit new crank shaft seals without splitting the case (Read 1642 times)
oldyzman
250 two stroke!
April 17, 2013, 08:53:32 pm »
Seeing the bottom end is good on the bike i am resto'ing can the crank seals be replaced without splitting the cases as i would think the seals should be replaced.
I have looked at some info but cannot tell?
Cheers Brett
smed
Re: CR125RZ, is it possible to fit new crank shaft seals without splitting the case
April 19, 2013, 12:48:30 pm »
I would think you should be able to
Marque Remarks
Honda
