Author Topic: whats the best glue for seat covers?  (Read 5969 times)
Offline paul
« on: March 22, 2013, 07:33:03 pm »
whats the best ?  for sticking the edges onto seat base,s
« Last Edit: March 22, 2013, 07:35:32 pm by paul »
Offline Barra
Re: whats the best glue for seat covers?
« Reply #1 on: March 22, 2013, 07:58:41 pm »
Must be a metal seat base yeah?
Otherwise, for plastic bases 6mm x 10/12mm crown staples is the go.
Offline frostype400
« Reply #2 on: March 22, 2013, 08:19:30 pm »
I would say staples if plastic but I used this on my chargers exterior door vinyl at first I thought this is crap as it didn't seem to set but the next day it went off well and it stuck nice and flat and looks the goods.
http://www.ebay.com.au/itm/LOCTITE-CONTACT-ADHESIVE-CA3-250ML-MULTI-PURPOSE-SUPER-STRENGTH-CAR-TRIMS-PLASTI-/300865086589?pt=AU_Car_Parts_Accessories&hash=item460cf4e47d&_uhb=1#ht_5323wt_313
1971 tm400 and PE's
Offline paul
« Reply #3 on: March 22, 2013, 08:21:24 pm »
plastic ,but    i  have to cut a gap in the cover  to go around the mounting bracket.  for some reason the new seat base is a tight fit on the frame rails so i have to heat the base and bend it out slightly to fit the side covers  under the seat itself  hence a couple off dabs off glue in the corners and here and there
Offline frostype400
« Reply #4 on: March 22, 2013, 08:22:22 pm »
Here is a pic of the vinyl I stuck on it is not a lot of glue 250ml I will have to buy more as I used more than half to do the two doors. :)
1971 tm400 and PE's
Offline paul
« Reply #5 on: March 22, 2013, 08:27:46 pm »
for this thing so id like something that dries clear
Offline frostype400
« Reply #6 on: March 22, 2013, 08:29:34 pm »
Ok the loctite stuff I don't know what it I dried like cause I cant see it I know it went on a yellowy colour.
1971 tm400 and PE's
Offline frostype400
« Reply #7 on: March 22, 2013, 08:31:45 pm »
I could put some on some paper for you tomorrow and see what it dries like if you'd like.
1971 tm400 and PE's
Offline paul
« Reply #8 on: March 22, 2013, 08:39:40 pm »
thanks
Offline frostype400
« Reply #9 on: March 22, 2013, 08:42:50 pm »
No worries will do nice looking Maico too. :)
1971 tm400 and PE's
Offline Barra
« Reply #10 on: March 22, 2013, 08:48:37 pm »
Contact glues generally retain their original colour when dry.  Yellow, red, green -  I've used drums of it over the years.  There's all different sorts out there but most do the same thing - generally stick like shit to a blanket!  Paint the glue on both surfaces - let air dry for a few minutes till touch dry - then press together. You only get one go!
Excess can be cleaned of with thinners (or turps will do). Won't hurt cover or base.
Paul, you can unbolt seat brackets, staple on cover (with glue too if you like) then bolt brackets back on. Just need to keep an eye on bolt tension after that.  If you want to get real fussy, unbolt the brackets after they leave an impression on the vinyl ( and glue has set) and them trim exactly to bracket shape!
Still reckon you should do it all with staples (with a bit of glue to make us all feel better  :D)
Very nice bike!!  Whats that gold donger thingy hanging over muffler?
Offline Paul552
  • HEAVEN #552
« Reply #11 on: March 22, 2013, 09:02:59 pm »
Hey charger !!!
Nice car what about a few more pics!!!!
Offline paul
« Reply #12 on: March 22, 2013, 09:17:50 pm »
the gold donger is a clamp .im useing glue and staples
Offline frostype400
« Reply #13 on: March 22, 2013, 10:07:04 pm »
Paul552
posted a couple more to this topic I haven't taken many because I am busy working on it.
http://ozvmx.com/community/index.php?topic=4980.180
1971 tm400 and PE's
Offline frostype400
« Reply #14 on: March 23, 2013, 05:15:53 pm »
G'day Paul,
Like I said I would here is the result yellow like the glue but I know of something that may work I haven't tried outside of its usual purpose and that is clear pvc glue you can buy a small bottle of that from your local plumbing store but like I said I haven't tried it on anything other than pvc to pvc but it is stuck to my work pants and has been stuck to my hands a lot too.
The stuff my local upholsterer uses is spray on and it is a yellowy looking glue to, thanks Michael.
1971 tm400 and PE's
