Author Topic: Bultaco front bake orient attain  (Read 6087 times)
Offline huskibul
Re: Bultaco front bake orient attain
« Reply #15 on: February 22, 2013, 03:32:00 pm »
     Just remember Jerry as your flyin' thru the air --- it's all for "the cause"    :-\
Offline pancho
« Reply #16 on: February 22, 2013, 03:38:42 pm »
 Would that make the machine accelerate?
COOL! what a great mod!
 Must try it!
 cheers pancho.
« Reply #17 on: February 22, 2013, 03:54:54 pm »
I reverse all of my Maico front wheels....you have to make up a new stay (or find a Wheelsmith stay like I have) and possibly use a Yamaha cable, depending on the model. It can't be too hard to do it on a Bully surely?
                                                               below: My modified left side stopper.
                                                               Below: the stock right side setup
Offline Moto
« Reply #18 on: February 22, 2013, 07:55:20 pm »
I have thought about reversing the brake on my Mk7/8 for all the same reasons you have said,BUT,I think that when you do this on a Bully the brake arm ends up in a position that doesn't work. Jerry if you can get it to work,we will all definately copy it!  8):D
« Reply #19 on: February 22, 2013, 09:05:43 pm »
Stay tuned I may have a cunning plan! J
« Reply #20 on: February 22, 2013, 11:26:14 pm »
Use a Yamaha front wheel. 8)
Offline SON
« Reply #21 on: February 22, 2013, 11:43:18 pm »
Just as Mark said use Yamaha Wheels that means back as well,
Then the Bully will stop,
Norm Fraser owned a Wreckers, Yamaha wheels were raided for most Fraser supported Bully's
Offline cemotobull
« Reply #22 on: February 23, 2013, 08:20:28 am »
I used to run the reverse brake mod on my Bultaco Hill Climber in the 70's. It worked well when you started rolling backwards.
Offline JC
« Reply #23 on: February 23, 2013, 10:21:04 am »
You'd have to relocate the bolt on the brake plate for the stay arm to a diff position
« Reply #24 on: February 23, 2013, 10:38:44 am »
That's right JC I'm conducting a feasibility study this arvo. J
« Reply #25 on: February 23, 2013, 01:18:26 pm »
Ok preliminary report. Changed the fork legs over (looks better already) have to fabricate a new brake stay arm and fit cable guide to it ala MK7 et al. Also have to swap over brake shoe pivot pin with brake actuation pin. Bit of machining required but a mate is a toolmaker. I reckon it will work. The cable will then run down the front of the fork the same as Mk7 but think mirror image. Let you know after test ride. Hope it doesn't pull to the left! Oh by the way this is on my MK3 Pursang. If it works out ok I will do my Jim Pomeroy Frontera. J PS will have to work out the "new cable length" hopefully I can get something off the shelf.
