Author Topic: Bultaco front bake orient attain  (Read 6079 times)
« on: February 22, 2013, 08:05:43 am »
Is it just me or has anybody wondered why Bultaco chose to activate the front brake from the the throttle side. It makes for a tight radius on the poor old brake cable as well as compromised cable routing. I'm thinking of reversing the hub to achieve a less torturous path for the cable. Any thoughts! J
Re: Bultaco front bake orient attain
« Reply #1 on: February 22, 2013, 08:07:05 am »
Make that orientation. Sorry no glasshies
« Reply #2 on: February 22, 2013, 08:08:04 am »
Make that brake! WTF
Offline Canam370
« Reply #3 on: February 22, 2013, 08:09:42 am »
Reverse it if you can. I could never see any redeeming reason for the throttle side brake plate arrangement.
I thinks you get the award for the most interesting/confusing thread title  ;D
« Reply #4 on: February 22, 2013, 08:23:13 am »
Yeah thanks for that Can Am. There's a lesson here " don't post early in the morning ". Still if others are curious it will interesting to see the feedback. J
« Reply #5 on: February 22, 2013, 08:43:28 am »
 Can Am I've just noticed in 29 more posts you will as legendary as me! J
Offline Canam370
« Reply #6 on: February 22, 2013, 09:28:51 am »
Then I too can enter the realm of lost souls and no life?  :-[
Offline huskibul
« Reply #7 on: February 22, 2013, 09:41:18 am »
   Hey jerry ! ive been looking at that brake setup for a while ,there was a US import 125 pursang on ebay a while back that had the mod .the only thing i can see is the  brake the backing plate would be pushing the brake stay instead of pulling against it - maybe a steel or thicker alloy stay would be peace of mind ,would probably give better feel at the lever  :)
« Last Edit: February 22, 2013, 10:50:06 am by Huskibul »
Offline huskibul
« Reply #8 on: February 22, 2013, 09:43:56 am »
     Ps - great headline ! sound's like you were turning japanese half way thru  :D
« Reply #9 on: February 22, 2013, 10:33:46 am »
Turning Japanese "I really think so!"
Offline matcho mick
    • Moto Tumbi
« Reply #10 on: February 22, 2013, 10:41:00 am »
interesting!,Brads (090) ossa phantom has f/brake swapped to l/h side,i remarked about this to Brad,"thats how it was/came to me,& it works spoton" ,i could never get the small brake to work,maybe thats why it's moved over to the l/h side,the only diff is the fork oil drain plugs are forward,(forks are swapped over too),still having cafeeine hit so not sure about leading/trailing brake shoe operation atm ;D, :P
Offline Brian Watson
  • First Penton in OZ
« Reply #11 on: February 22, 2013, 12:46:55 pm »
Yep..we do the same with a Husky...swap the brake onto the left side....as stated above..makes for a much more gentle arc on the cable...easy on a HVA as both legs are cast the same.....I think the works guys did it also back in the 70's....
Attaining forward baking in the orient, Spanish style
« Reply #12 on: February 22, 2013, 01:51:06 pm »
Yes I had noticed you blokes were as hopeless as each other ;D
If you swap the brake to the other side wouldn't that reverse the braking action and make the bike accelerate instead?
« Reply #13 on: February 22, 2013, 03:12:54 pm »
Thanks guys you've suitably armed me with an inappropriate level of over confidence. I will send photos if it works (from home) or hospital if it does'nt. Come to think of it its not possible for the brakes to be even worse than before! J
« Reply #14 on: February 22, 2013, 03:16:09 pm »
As for you Geoffrey back to the sweat shop least I order an up pipe for the Bulty! J
