Author Topic: 84 Honda CR 250 Modifications  (Read 54996 times)
Offline Kenneth S (222)
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« on: January 19, 2013, 08:13:16 pm »
Hi Guys,
Does anyone know a source for wide footpegs for this model?
I also find the front break lever sits too far out and there is no adjustment to it. Was it stock this way? Is there a good solution you have come across for this to make it adjustable or at least sit closer to the grip?
Thanks,
Ken
Kenneth S
Go For It
Race Bike History
Re: 84 Honda CR 250 Modifications
« Reply #1 on: January 19, 2013, 09:19:08 pm »
send your existing pegs to GMC - not only will they come back wide but then bolt straight on!
Offline PCMAX
« Reply #2 on: January 19, 2013, 10:29:01 pm »
Ken, I got a set of these on ebay recently
http://www.ebay.com/itm/280919421622?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The price was right even though the shiping cost is over the top. They took a bit of modifying to fit my 82 CR125 though, had to mill 1mm from either side to fit the frame, drill out the hole for the pin and drill some holes for the return spring but overall they're not to bad,
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #3 on: January 22, 2013, 10:13:05 pm »
Cheers for that
Kenneth S
Go For It
Race Bike History
« Reply #4 on: January 22, 2013, 10:34:02 pm »
Drill a hole and tap a 6 mm thread through the front of the perch so you can put an allen key screw/bolt in that acts as a stop/adjuster for the lever
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #5 on: January 23, 2013, 07:08:20 am »
Excellent! Thanks. So bloody obvious :-\
Kenneth S
Go For It
Race Bike History
Offline Ted
« Reply #6 on: January 23, 2013, 04:45:21 pm »
Barsby was wrong then.....you do have some use
81 YZ 465 H   77 RM 125 B
Offline 09.0
« Reply #7 on: January 23, 2013, 05:26:58 pm »
   That's it though. He just peaked!
« Reply #8 on: January 23, 2013, 09:49:47 pm »
The sad thing is, I think Vandy gave me this tech tip a few yrs ago
Offline holeshot buddy
  • sunshine coast qld
« Reply #9 on: January 23, 2013, 10:24:25 pm »
late model ktm ;)
follow me to first turn
Offline Ted
« Reply #10 on: January 24, 2013, 12:13:21 pm »
I will retract my statement then............you remain useless
« Last Edit: January 24, 2013, 12:15:13 pm by Ted »
« Reply #11 on: January 24, 2013, 07:13:56 pm »
A little trick that got done to my CZ at 1 stage to move the lever closer to the bars was a cable tie looped around the perch somewhwere between the cable & pivot, works the same as the screw without weakening the perch
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #12 on: January 24, 2013, 08:29:10 pm »
I like it! An easy fix.
Kenneth S
Go For It
Race Bike History
Offline Hardo
« Reply #13 on: January 24, 2013, 08:36:02 pm »
Get a shorty style lever Ken? I did that and the lever sits a lot closer as it's shaped towards the grip.
Hey where's the frame mate?? I am ready to do it for you mate !! You dropping it off this weekend?  :)
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #14 on: January 27, 2013, 01:16:59 pm »
Hey Dave,
Can't find a shorty for this model. There must be an embargo on them I'm not aware of.
If I don't make it up to you over the weekend, I'll ship the frame up next week by Toll.
Kenneth S
Go For It
Race Bike History
