Author Topic: YZ 250 J shock  (Read 1380 times)
maico police
YZ 250 J shock
« on: January 05, 2013, 07:07:15 pm »
Offline holeshot buddy
  • sunshine coast qld
Re: YZ 250 J shock
« Reply #1 on: January 05, 2013, 11:10:53 pm »
they will also fit a H model  ;)
follow me to first turn
Re: YZ 250 J shock
« Reply #2 on: January 05, 2013, 11:40:37 pm »
Me thinks they have a shorter shaft travel, stiffer linear rate spring.
maico police
Re: YZ 250 J shock
« Reply #3 on: January 06, 2013, 09:21:45 am »
Same travel, slightly longer shock overall but they can be shortened to the same length. The J spring has a single rate (because of the linkage system) so you use your H spring on them if you want to use them on the earlier bike to give it that initial plushness.
I ran one of these on my 465 but they ain't EVO legal because they came off the pre 85 bike.
Offline Zakk
  • rAdelaide
Re: YZ 250 J shock
« Reply #4 on: January 06, 2013, 04:01:39 pm »
they'll fit the earlier models, i've got a YZ490J shock for my IT250J, i had it shortened by 10mm to keep the ride hight the same. these J shocks are better than the earlier one's as they have a larger diameter shaft, plus the adjustable compression dampning.
