Author Topic: syn castor oil  (Read 3261 times)
Offline gra1961
syn castor oil
« on: December 29, 2012, 08:54:17 am »
anyone had any problem with running penrite castor syn blend oil?i only just switched to it on my 84 ktm 250 and did a big end after a couple of rides.was running at 33:1 on premium unleaded.maybe just coincedence?
Re: syn castor oil
« Reply #1 on: December 29, 2012, 11:02:30 am »
IMO oil has better in the last 30 years so why use something that is based around old tec? I do like the smell thou.
Offline craignduke
Re: syn castor oil
« Reply #2 on: December 29, 2012, 12:01:08 pm »
don't use premium fuel in old bikes
Offline Paul552
  • HEAVEN #552
Re: syn castor oil
« Reply #3 on: December 29, 2012, 12:02:59 pm »
Why?
Lower burn temp? Less chance for detonation?
Less power?
Offline ozktm
Re: syn castor oil
« Reply #4 on: December 29, 2012, 08:40:42 pm »
I run it, and have for a couple of years now. No issue in my bikes.
I pull the top end off my 495 the other week and was nice and clean/wet with the oil.
How long have you had the rod in the bike, and what use has it had?
Cheers Adrian
Regards,
Adrian Goold #101
Offline gra1961
Re: syn castor oil
« Reply #5 on: December 30, 2012, 07:24:51 am »
yeah the bike had been sitting for i guess ten years.when i got it i just cleaned out the carby and fuel tap and it started so i just rode it ,i had done about 5 hrs on it before i changed to the penrite castor syn oil.when i pulled the top off the motor when it stopped it wasnt dry it probably was just that the motor was tired.anyway got another bike over xmas to to take the motor out of that has a corroded clutch cover and was going to use the clutch cover of the one with the buggered big end but allthough they are both 85 ktm 250s 544 prefix engines the cover is different .they have different water pump drives.back to square one
Re: syn castor oil
« Reply #6 on: January 12, 2013, 09:45:04 pm »
If its been sitting for ten year I'd say the mains already had rust in it and it was only a matter of time before it scored itself to fail.  Often if you see an old motor when you turn the crank over you see pits in the crank wheel where its been siting in moisture in the bottom of the crank...... If cranks pitted or discoloured you just had a laid up failure that's all.
