Author Topic: TM250 ring  (Read 2292 times)
Offline SimonC
TM250 ring
« on: December 20, 2012, 06:54:01 pm »
Needing the top L shaped ring for a 72mm (+080) Wiseco Piston, is there any Wiseco stockists out here in OZ?
Simon
Re: TM250 ring
« Reply #1 on: December 20, 2012, 07:55:47 pm »
« Last Edit: December 20, 2012, 08:01:16 pm by oldfart »
Offline VMX60
Re: TM250 ring
« Reply #2 on: December 20, 2012, 08:32:29 pm »
That must be a old green box Wiseco i have some new old style Wiseco rings need the number stamp on the pin boss of the piston to check if i can Help
Offline VMX60
Re: TM250 ring
« Reply #3 on: December 20, 2012, 11:44:17 pm »
The 2835cd are the late type of ring the Green box early Wiseco had a large step dykes top ring which type do you require
Offline SimonC
Re: TM250 ring
« Reply #4 on: December 21, 2012, 04:20:55 pm »
I guess the old style L shape - i will see if I can find a number on it.
Re: TM250 ring
« Reply #5 on: December 21, 2012, 06:16:47 pm »
I always had problems with those L shaped rings breaking in my TM's, I'd be looking for another piston if I was you.
