Marque Remarks
Suzuki
TM250 ring
Topic: TM250 ring (Read 2291 times)
SimonC
B-Grade
TM250 ring
December 20, 2012, 06:54:01 pm »
Needing the top L shaped ring for a 72mm (+080) Wiseco Piston, is there any Wiseco stockists out here in OZ?
Simon
Re: TM250 ring
December 20, 2012, 07:55:47 pm »
Something like this ..........Have you rang Serco as they are the agents
http://www.ebay.com.au/itm/WISECO-PISTON-RING-SET-72MM-2835CD-300-EXC-MXC-XC-XCW-/380536749607?pt=AU_Motorcycle_Parts_Accessories&hash=item5899c1fe27
Last Edit: December 20, 2012, 08:01:16 pm by oldfart
VMX60
A-Grade
Re: TM250 ring
December 20, 2012, 08:32:29 pm »
That must be a old green box Wiseco i have some new old style Wiseco rings need the number stamp on the pin boss of the piston to check if i can Help
VMX60
A-Grade
Re: TM250 ring
December 20, 2012, 11:44:17 pm »
The 2835cd are the late type of ring the Green box early Wiseco had a large step dykes top ring which type do you require
SimonC
B-Grade
Re: TM250 ring
Reply #4 on:
December 21, 2012, 04:20:55 pm »
I guess the old style L shape - i will see if I can find a number on it.
John Orchard
^^^ July 1984
Re: TM250 ring
Reply #5 on:
December 21, 2012, 06:16:47 pm »
I always had problems with those L shaped rings breaking in my TM's, I'd be looking for another piston if I was you.
Marque Remarks
Suzuki
TM250 ring
