Author Topic: DT1 clutch from hell  (Read 11122 times)
« on: November 03, 2012, 04:29:34 pm »
Hi guys I have a DT1 with a clutch that Arnie would find hard to pull and after breaking my left paw its now too much . I know its only on the start line but this clutch is a bitch , Any ideas ? what if I take out 3 of the springs ?  any help would be appreciated . Iain
Re: DT1 clutch from hell
« Reply #1 on: November 03, 2012, 05:58:28 pm »
Weld an extension on the little actuator arm about 10 mm so there is better leverage, wont hurt the cable pulling on a slight angle (YZB's had this done at the factory....you can still buy them new off evilpay but expect to pay around a $100 for one). Also, dont use the cheapie lever sets, you might have to muck around with diferent ones untill you get it right. YZA's are a shocker std aswell.
SPANISH ARMADA
« Reply #2 on: November 03, 2012, 06:59:27 pm »
iain it will be that actuator on the side cover the plastic worm will be st###ed if u get one from yamaha to suit a gsxr they r steel and with a little mod they bolt in let me know if u dont have any luck will get u a part no cheers
« Reply #3 on: November 03, 2012, 08:08:32 pm »
The last time I looked the GSXR was made by Suzuki. Are you sure you don't mean XS650?
« Reply #4 on: November 03, 2012, 09:23:38 pm »
Sorry to burst your bubbles boys but the it's a falacy that TX/XS 650 actuators fit...I bought one the other day to see because nobody could say 100% they fitted...YZA/B (and Im guessing DT/RT's) have  3 splines and the road bike has 4!!!....obviously the roady has a bigger clutch so was made with 4 splines to spread the love...its also alot longer in the spline and where the cable picks up....hopefully Ill have my new clutch actuator covers ready soon. Cheers big ears.
« Reply #5 on: November 03, 2012, 09:47:43 pm »
Joan I too tried the steel XS650 actuator and also found that it was a no go. I got excited and looked up the GSXR Suzuki version on eBay just in case Armada was onto something but it's nothing like the Yammy unit. Until someone comes along with a repro version that doesn't split the first time we pull in the clutch, we're stuck with what we've got.
« Reply #6 on: November 03, 2012, 10:29:10 pm »
I think mine has the rd250 one. The pull is steal Nd the come with the female which us plastic. Wen you drop a chain it took out he old female side in the cover, so it was cut off Nd the new plastic coil bolts straight on. The new steel helix mates with it as there a pair and it works a treat.
Offline yamaico
« Reply #7 on: November 03, 2012, 10:51:33 pm »
You've outdone yourself this time Freaky ;D ;D ;D. I'm just heading down to the preschool to see if a toddler can decipher your post for me. ;D
« Reply #8 on: November 03, 2012, 11:14:31 pm »
Can you write that in English now Freaky instead of pigmy swahealy broken English?...I can understand a drunk sweaty easier that that.
« Reply #9 on: November 03, 2012, 11:43:24 pm »
I think he may be using ye olde sailor speak. Makes more sense if you say it out loud with a broad accent, aye me hearties, etc?
btw, it's spelt Swahili you twit.
« Last Edit: November 04, 2012, 12:44:53 am by mainline »
Offline bazza
« Reply #10 on: November 04, 2012, 08:21:34 am »
WTF
Embrace patina
« Reply #11 on: November 04, 2012, 10:20:24 am »
I've managed to translate it enough to read that Freaky reckons the RD 250 actuator fits. After shelling out for an XS650 actuator after we were told that they would work and finding that it didn't, I'm a tad wary of trying this until someone can verify that it fits. Here's what the RD setup looks like, suspiciously like the XS650 version :-\........................
                                                      Below: XS650 actuator
« Last Edit: November 04, 2012, 11:04:16 am by firko »
« Reply #12 on: November 04, 2012, 07:57:19 pm »
thanks guys , Davey  yes im using cheep levers swopped over to a old Yam lever much improved . the question about removing three of the springs still stands
anyone know if this would work ? Iain
« Reply #13 on: November 04, 2012, 10:29:27 pm »
forkin iPhone iPad bullshit, I know what I typed, fork knows what it did.
« Reply #14 on: November 04, 2012, 10:30:55 pm »
Firko it works cause you change them in as a pair. When I'm home next ill foto one in a case
